| Stltri |
Sep 15 2020, 04:28 PM
Member ![]() ![]() Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
Been trying to track down a clunk from the driver front end. Car is a 74 with Koni adjustable insert/shocks on all 4 corners. Looks like its coming from the shock on driver side at the top. Something is loose inside the shock tube and/or cover which duplicates what I hear/feel while driving. I checked everything else on the arms/rack/torsion bars/ball joint and everything tight (since I just also recently replaced all bushings etc). So I wanted to remove the shock to take a look but could not remove the nut after loosening it (while countering with a pipe wrench). I suspect the tab washer (which usually locks the nut and prevent it from spinning) broke. I have read that maybe a impact wrench (I have a cordless and corded impact but not air impact wrench) may spin it loose but may also damage the shock internals so I have not tried that route? Any other ideas on how to remove the nut?
| mepstein |
Sep 17 2020, 03:18 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,017 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
There’s a 2-3mm gap with bilstein inserts so the gap you have might be normal. I checked with Bilstein tech dept and they said they get asked all the time but it’s designed to have a gap rather than bottom out and still be a little loose. I did t know about other brands but they might be similar design.
Stltri help with removing front shock top nut (Koni) Sep 15 2020, 04:28 PM
bdstone914 Grip the dished washer below the nut with some sli... Sep 15 2020, 04:46 PM
Stltri
Grip the dished washer below the nut with some sl... Sep 15 2020, 05:17 PM
porschetub Bruce nailed it :trophy: ,most likely the locking... Sep 15 2020, 05:21 PM
mepstein I use an impact wrench to remove. Takes two second... Sep 15 2020, 05:24 PM
Stltri
I use an impact wrench to remove. Takes two secon... Sep 15 2020, 06:23 PM
Stltri
[quote name='mepstein' post='2851623' date='Sep 1... Sep 16 2020, 12:55 PM
bdstone914 @Stltri
You do have the wheel off the ground cor... Sep 16 2020, 05:52 PM
Stltri
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 16 2020, 07:05 PM
ClayPerrine
Clunks are usually from the large strut top nut u... Sep 16 2020, 01:00 PM
Stltri
Clunks are usually from the large strut top nut ... Sep 16 2020, 05:17 PM
mepstein Lube the rod where it passes through the rubber.
... Sep 16 2020, 05:32 PM
Stltri
Lube the rod where it passes through the rubber. ... Sep 16 2020, 07:04 PM
rhodyguy Have you pulled the shaft free of the bushing? Pul... Sep 16 2020, 09:52 PM
Stltri
Have you pulled the shaft free of the bushing? Pu... Sep 17 2020, 01:52 PM
Stltri
There’s a 2-3mm gap with bilstein inserts so th... Sep 17 2020, 05:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 10:00 AM |
