> help with removing front shock top nut (Koni)
Stltri
post Sep 15 2020, 04:28 PM
Been trying to track down a clunk from the driver front end. Car is a 74 with Koni adjustable insert/shocks on all 4 corners. Looks like its coming from the shock on driver side at the top. Something is loose inside the shock tube and/or cover which duplicates what I hear/feel while driving. I checked everything else on the arms/rack/torsion bars/ball joint and everything tight (since I just also recently replaced all bushings etc). So I wanted to remove the shock to take a look but could not remove the nut after loosening it (while countering with a pipe wrench). I suspect the tab washer (which usually locks the nut and prevent it from spinning) broke. I have read that maybe a impact wrench (I have a cordless and corded impact but not air impact wrench) may spin it loose but may also damage the shock internals so I have not tried that route? Any other ideas on how to remove the nut?
post Sep 17 2020, 03:18 PM
914-6 GT in waiting
There’s a 2-3mm gap with bilstein inserts so the gap you have might be normal. I checked with Bilstein tech dept and they said they get asked all the time but it’s designed to have a gap rather than bottom out and still be a little loose. I did t know about other brands but they might be similar design.
Stltri
post Sep 17 2020, 05:42 PM
QUOTE(mepstein @ Sep 17 2020, 02:18 PM) *
That makes sense. Thanks for everyone's help. Hopefully reassembly will be smoother. Now waiting for replacement hardware from Koni (tab washer, dished washer, nut). Thanks to Mason of Koni-NA.
Actually found a thread similar to my problems, not sure why I didn't find it earlier. @krieger had a great idea of cutting the cover by 1 1/2" to expose the gland nut when car is lifted but covers it when down on the ground. This allows quick inspection and tightening of the gland nut if needed. Anybody else done this?
http://www.914world.com/bbs2/index.php?showtopic=288552
Stltri   help with removing front shock top nut (Koni)   Sep 15 2020, 04:28 PM
bdstone914   Grip the dished washer below the nut with some sli...   Sep 15 2020, 04:46 PM
Stltri   Grip the dished washer below the nut with some sl...   Sep 15 2020, 05:17 PM
porschetub   Bruce nailed it :trophy: ,most likely the locking...   Sep 15 2020, 05:21 PM
mepstein   I use an impact wrench to remove. Takes two second...   Sep 15 2020, 05:24 PM
Stltri   I use an impact wrench to remove. Takes two secon...   Sep 15 2020, 06:23 PM
Stltri   [quote name='mepstein' post='2851623' date='Sep 1...   Sep 16 2020, 12:55 PM
bdstone914   @Stltri You do have the wheel off the ground cor...   Sep 16 2020, 05:52 PM
Stltri   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 16 2020, 07:05 PM
ClayPerrine   Clunks are usually from the large strut top nut u...   Sep 16 2020, 01:00 PM
Stltri   Clunks are usually from the large strut top nut ...   Sep 16 2020, 05:17 PM
mepstein   Lube the rod where it passes through the rubber. ...   Sep 16 2020, 05:32 PM
Stltri   Lube the rod where it passes through the rubber. ...   Sep 16 2020, 07:04 PM
rhodyguy   Have you pulled the shaft free of the bushing? Pul...   Sep 16 2020, 09:52 PM
Stltri   Have you pulled the shaft free of the bushing? Pu...   Sep 17 2020, 01:52 PM
mepstein   There’s a 2-3mm gap with bilstein inserts so the...   Sep 17 2020, 03:18 PM
Stltri   There’s a 2-3mm gap with bilstein inserts so th...   Sep 17 2020, 05:42 PM
- Lo-Fi Version Time is now: 25th November 2026 - 10:00 AM
