914-6 heater hoses, Size and Length for 914-6 hoses |
7T914-6 |
Sep 18 2020, 06:43 PM
Newbie Group: Members Posts: 10 Joined: 11-July 20 From: San Anselmo, CA Member No.: 24,485 Region Association: Central California |
I'm confused. Can someone clarify if there are two different hose types, length and color. There appears to be a high temp hose (orange - 60mm x 320mm long) and a second hose that is a different color and length (tan 60mm x 420mm) is that right? Seems easy to source the orange "high temp" hose but anyone found a source for the other one?
I have Billy Boat headers with heat exchangers but they are not connected yet. Do we need the hose clamps at the heater (flapper) box that has the cable guide or will any 600mm+ clamp work. Anyone find a source for cadmium plated clamps or the original slide calms vs. the standard screw type clamps? Any help appreciated. Thanks |
mb911 |
Sep 18 2020, 07:04 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I'm confused. Can someone clarify if there are two different hose types, length and color. There appears to be a high temp hose (orange - 60mm x 320mm long) and a second hose that is a different color and length (tan 60mm x 420mm) is that right? Seems easy to source the orange "high temp" hose but anyone found a source for the other one? I have Billy Boat headers with heat exchangers but they are not connected yet. Do we need the hose clamps at the heater (flapper) box that has the cable guide or will any 600mm+ clamp work. Anyone find a source for cadmium plated clamps or the original slide calms vs. the standard screw type clamps? Any help appreciated. Thanks The b&b are not stock location so lengths will very.. I will also tell you don't expect much heat from them.. They really dont produce much heat. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:03 AM |
