| 808 WRX |
Sep 22 2020, 12:16 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California
I picked up a '75 roller a few months ago. Its a decent shell but I need to replace the rear half of the floor pans, the bottom edge of the inner and outer firewall and get a better look at the longs. The longs look pretty good from the outside, but of course there is a hole under the battery tray so time will tell.
I'm planning to build a rotisserie and wanted to run my idea by some more experienced folks. Honestly, supporting the car from the ends via the bumper mounts scares me, so I'm going to make one similar to the one by restoration design with the two hoops. The difference being that I would essentially build a rectangular cart on wheels that would mount to the front suspension area and either the rear suspension or the transmission crossmember. I would then bolt the hoops to the cart. The main benefit being that the cart would add structural rigidity to the body by reducing the twisting/bending forces. I would still use adjustable bracing from the upper seatbelt bolt towards the front of the car to keep the door gaps/targa top dimensions in spec. Has anyone done something like this? Is it worth the extra effort? How much space should I leave between the cart and the bottom of the car (about 8")? I'm thinking rectangular tubing, can I get away with 1.5" x 3" or smaller/larger? (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) |
| VaccaRabite |
Sep 22 2020, 10:26 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I did it.
Strip the car. Do the structural stuff and brace the hell out of it. Since yours is a 75 this is stupid simple. Take the bumpers off and attach the rotisserie to the shock bumper mounts. That's exactly how I did it on mine. (IMG:https://live.staticflickr.com/87/236318251_7c909895da_o.jpg) This is when I was test fitting the one I built out of HF 700lbs engine stands. You can see I just used a cross bar and bolted it directly to the bumper shocks. I stacked washers into the gap for the shock mounts to make sure the ears did not collapse. The balance point was SPOT ON. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1600792000.1.jpg) I tied the two hacked up stands with a cross bar that used the existing front leg mount. Easy to build. When I was done I sold the Rot quick and for a profit to boot. Car was up on it for 2 years while I did the restoration. Zach |
| Superhawk996 |
Sep 22 2020, 11:56 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I did it. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22428-1600797417.1.jpg) (IMG:style_emoticons/default/confused24.gif) What am I missing here? What's holding the back end up? Just the rear end of the rotisserie tipped sideways? Front rotisserie oriented normally as two points on front and the rear is just enough to keep it all from collapsing? Not making sense to me. I wouldn't be brave enough to crawl under there but you've clearly survived so I must not be understanding. |
| VaccaRabite |
Sep 22 2020, 12:16 PM
I did it. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-22428-1600797417.1.jpg) (IMG:style_emoticons/default/confused24.gif) What am I missing here? What's holding the back end up? Just the rear end of the rotisserie tipped sideways? Front rotisserie oriented normally as two points on front and the rear is just enough to keep it all from collapsing? Not making sense to me. I wouldn't be brave enough to crawl under there but you've clearly survived so I must not be understanding. In this picture the body of the car is supported on Jack stands front and rear. Only the back end of the rotisserie is attached as I was testing fitment. The rotisserie is laying on its side, not supporting anything. IIRC I wanted to be sure that once I had the car bolted on I would be able to rotate the car around the rotisserie and I did this by lifting the free end and making sure everything cleared as it spun on its axis. Or am I misunderstanding? Are you concerned about mounting the car via the bumper mounts? The car was on the rotisserie very stoutly, yet rotated easily on its axis. Zach |
808 WRX Rotisserie Build Ideas Sep 22 2020, 12:16 AM
Superhawk996 You really don't want to do structural reapirs... Sep 22 2020, 05:28 AM
808 WRX Thank you!
Ohh yeah, I forgot about the ounte... Sep 22 2020, 08:21 AM
Superhawk996 I get it now. Thanks for clarifying.
I think OP ... Sep 22 2020, 01:32 PM
914forme LOL engine stands are so, boring.
I built one a w... Sep 22 2020, 02:04 PM
mlindner 808, if you have a lift....then just build a dolly... Sep 23 2020, 05:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:31 AM |
