DOOR HANDLES, Replacement |
struckn |
Sep 20 2020, 06:35 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
My '74 914's driver side door handle broke a couple months ago. It cracked in two and I tried JB Weld to get it back together. Seemed to work great until last week when it broke again where I had the JB Weld covering the cracked area and over lapped the pot metal beyond the crack.
So I'm waiting for an after market replacement I ordered from Pelican. Their cost was less then half of an original Porsche replacement Handle's cost. Pelican described the original 914 Handles as one of the major problem areas to fail. We'll see how it goes, the reviews from others say it works, fits and looks the same. I had taken out the original Handle once before. It's not a hard fix. Only concern is how to remove the original Key mechanism from the original handle and install it in the after market Handle. I'll figure it out, can't be too difficult. Oh, when I ordered the replacement Pelican shows it to be the last one that had. Tally Hoe! Doug in New Freedom Pa. |
914sgofast2 |
Sep 22 2020, 04:53 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
In my experience the outer handle and the plastic/nylon operating cam lever tend to break because the door lock itself has become gummed up with years of dirt, oil, grease and gunk deep down in the mechanism. Do you doors a favor and take off the door lock and soak it in parts cleaner overnight and then use an air hose to blow out the gunk the next morning. Oil it up and put it back on the car. I was amazed at how much easier my doors worked after doing this.
Mikey914 |
Sep 23 2020, 12:26 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
In my experience the outer handle and the plastic/nylon operating cam lever tend to break because the door lock itself has become gummed up with years of dirt, oil, grease and gunk deep down in the mechanism. Do you doors a favor and take off the door lock and soak it in parts cleaner overnight and then use an air hose to blow out the gunk the next morning. Oil it up and put it back on the car. I was amazed at how much easier my doors worked after doing this. It should break (or flex) as it is a "fuse" in the system. It can be replaced. Better it than the metal. |
Lo-Fi Version | Time is now: 10th June 2024 - 01:47 AM |
