> Valve Train Geometry with Cam., Beating a dead horse.
jaredmcginness
post Sep 8 2020, 01:14 PM
Hey guys,
Making headway on my 1911 build (no pun intended).
I have a few valve train questions. I've researched this a good bit the last few days and read a couple informative threads on here with some info (including one by @nditiz1 that went through a very similar issue)
I am trying to not over complicate this, so my tiny brain can make sense.
I was having an issue with my rockers, posted a photo of my heads on the 914world facebook group and got a great response from J. Raby with a lot of helpful info.
It seems I bit off a bit more than I can chew with valve train geometry.
(I understand he wrote a dissertation about Valve Geometry a number of years ago, but I cannot seem to find it.)
It does not surprise me that the fella/shop who built my bottom end didn't go into too much detail about this. He basically laid the numbers out and said "If I have X amount of cam lift, we need to machine the heads for dual springs to achieve X amount of clearance. All there is too it."
Maybe there is a bit more involved than that. (IMG:style_emoticons/default/smile.gif)
Specs:
-1911 (96x66mm)
-51cc heads - fresh.
-Scat c35 .495 Lift
-Scat solid lifters
-Scat dual HD springs, head machined.
Recommended additional purchases by Jake:
All available at Type4Store
-911 Swivel Foot / Machine rockers .060
-Solid Spacer and shims. Byebye rocker spring.
-8mm HD studs for strength.
Question:
With all of this added, it seems like the heads will be much more sound, and be able to handle the possibly over-sized lift on the cam.
-I have seemingly completed a proper valve adjustment using the "Lobe per lobe" technique. (I.E. Intake 3 fully open, adjust opposite rockers on 1) I cannot find a lot of info on the right way to do an adjustment with a large cam. Thoughts?
My TDC mark on the flywheel doesn't match up with the valves due to the ramp of this cam. (I think I understand that right)
-Does this geometry affect my pushrods? They SEEM to be working fine at their length. Do I need "chromoly"? Is this for strength and + cut to size?
I read all these threads on the Samba of guys running large cams with stock rods. (probably my engine builder posting that stuff (IMG:style_emoticons/default/biggrin.gif))
I would just like to do this right the first time.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1599592477.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1599592477.2.jpg)
Sounds like this motor is going to run like scat if I don't wrap my head around this and study a bit more. I'm really proud of what I have learned so far building this 914.
But I am just at the tip of the iceberg.
Feel free to just tell me to use the search function. (IMG:style_emoticons/default/beerchug.gif)
jaredmcginness
post Sep 23 2020, 05:31 AM
Hey guys,
I posted this info in my build thread, but I figured it is better suited here, incase anyone is following for their own type 4.
Update: been awaiting a lot of parts for my valve train. Everything has finally arrived!
With that said - and having read and taken notes on Raby's novel on Valve Geometry about 7 times - I began.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822307.1.jpg)
I ground the 1.7 rockers about .060. Started with ~ .504 and ended with around .437 on all of them. Filed flat and deburred on the buffing wheel.
I counter sank them to fit the Thorsten Peiper, Made in Germany swivel feet. (I didnt go OEM ((sorry Jake)), I paid $117 for these - about 1/3 the price of OE - we'll see how it goes. I couldn't find anything bad on these, unlike the El Cheapo $38 ones.) I also chased the threads after this photo.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822307.2.jpg)
I assembled the rocker assembly, HD studs, solid spacers, fresh HD washers.
One question I am looking for a few answers on:
Spacers on the rocker assembly...
Am I shooting to line the adjusters up with the valve, (by moving spacers left or right, and stacking between - see photo) dead center as close as I can, then shim later at half lift if needed?
Or just assemble the rocker shaft, evenly spaced washers and shim under the studs as needed later.
Should it be this layout?:
Stud|Rocker|SHIM|Spacer|SHIM|Rocker|Stud
Current layout is:
Stud|Rocker|SHIM|Spacer|Rocker|SHIM|Stud
I have a gap of .006 currently. I may be overthinking the assembly layout, may not matter at all.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822308.3.jpg)
I don't have a washer between every piece in the assembly. I'm told and am thinking this is OK... yes?
For mounting my magnetic base, I made a quickie bracket. For the hole pattern, I overlayed my intake gasket, and copied with a sharpie.
I haphazardly cut it with my grinder, as I ran out of wheels... Pretty sad for a professional sheet metal mechanic. (IMG:style_emoticons/default/lol-2.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822308.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822308.5.jpg)
Base mounted GREAT! Super solid!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600822308.6.jpg)
This is about as far as I got this evening...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1600823044.1.jpg)
I lined up the dial indicator. It looks pretty co linier right now. I want to get the angle dead on. Next is preload, then find full lift, and so on so forth.
Thanks all!
Jared
jaredmcginness   Valve Train Geometry with Cam.   Sep 8 2020, 01:14 PM
nditiz1   Hey Jared, I myself need to go back to my notes o...   Sep 8 2020, 02:08 PM
jaredmcginness   First, thank you for the awesome and thought out r...   Sep 8 2020, 04:08 PM
mepstein   Thanks Jake! Posted with permission: Here it ...   Sep 8 2020, 03:11 PM
jaredmcginness   Thanks Jake! Posted with permission: Here it...   Sep 8 2020, 04:10 PM
Jake Raby   Thanks Jake! Posted with permission: Here it...   Sep 14 2020, 08:53 AM
VaccaRabite   good stuff clipped... [url=http://www.914world....   Sep 14 2020, 10:41 AM
VaccaRabite   In short. You need cut to length pushrods. You nee...   Sep 8 2020, 08:52 PM
krazykonrad   Admins, can we nail this thread? This is literally...   Sep 9 2020, 06:28 AM
mepstein   Admins, can we nail this thread? This is literall...   Sep 9 2020, 07:40 AM
jaredmcginness   Admins, can we nail this thread? This is literall...   Sep 9 2020, 08:21 AM
VaccaRabite   Admins, can we nail this thread? This is literal...   Sep 9 2020, 08:44 AM
VaccaRabite   One more thing: TAKE PICTURES and post them up of...   Sep 9 2020, 08:49 AM
barefoot   Here's my dial indicator set-up, very low budg...   Sep 10 2020, 07:18 AM
Olympic 914   Using magnetic mount.   Sep 10 2020, 07:56 AM
VaccaRabite   :agree: Note how Olympic had the tip of the indica...   Sep 10 2020, 11:01 AM
jaredmcginness   Hey guys, I posted this info in my build thread, ...   Sep 23 2020, 05:31 AM
VaccaRabite   Its been too long since I set the spacers on my ro...   Sep 23 2020, 08:19 AM
nditiz1   When I had Tabari (theSamba) clearence the sides o...   Sep 23 2020, 08:55 AM
jaredmcginness   Hey guys, Thanks for the advice. I cut about 30q...   Sep 23 2020, 06:58 PM
jaredmcginness   Hey guys, Back at the Adjustment today. I milled ...   Sep 25 2020, 03:56 PM
nditiz1   Looking good Jared. I think I was able to capture...   Sep 25 2020, 04:48 PM
jaredmcginness   Okay Nick... so I missed that. Looking for valve a...   Sep 25 2020, 05:44 PM
nditiz1   You can confirm by throwing your old adjust in the...   Sep 25 2020, 06:11 PM
jaredmcginness   Morning, I finished up the part of the valve trai...   Sep 27 2020, 09:36 AM
- Lo-Fi Version Time is now: 6th July 2025 - 10:02 AM
