welp this happened, think mcfly think |
bludden |
Sep 23 2020, 01:22 PM
Member Group: Members Posts: 57 Joined: 15-June 20 From: Charlotte NC Member No.: 24,380 Region Association: South East States |
I didn't engage the parking brake hard enough and it rolled into a tree. At first my trunk lock was stuck but using the rubber mallet treatment it came loose - its got spring tension but nothing is releasing. I can't get the trunk to open. Most of my good tools as well as my targa top is in there. Any suggestions? I was thinking i could take the bolts off the front of the trunk and get in there but that seems to be a pretty bad option.
Mikey914 |
Sep 24 2020, 12:03 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That sucks.
You may be luck enough that you can locate a rear deck lid to repaint and I'm thinking it may be possible to pull out the damage. A pic of the inside trunk at the seam would let you know, but it's possible from the way the cross support goes that it could be pulled. From what I can see it should be able to be repaired at any reputable body shop. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:46 PM |
