Voltage drop |
Voltage drop |
Dave97 |
Sep 22 2020, 05:41 PM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
What is normal voltage drop when you turn on the lights? I’m just going off the volt meter, but I start at about 14.2 driving around, when I pull on even the first notch of the light switch I’ll drop to less than 13. Is it a ground issue? I understand that this a rather common. Thanks. Dave
Dave97 |
Sep 25 2020, 02:31 PM
Thanks everyone. What seems strange to me is the fact that the biggest voltage drop is just with the parking lights. In the past I have put relay's on a early 911 headlights to get direct power to them and not go thru the switch. I have checked the grounds at the headlight to the body and cleaned them. How do I check the "real" voltage? Do I need to verify the gauge? At an indicated 12.5 volts the headlights don't seem to dim. Suggestions?
Lo-Fi Version | Time is now: 22nd May 2024 - 09:05 PM |
