| pt_700 |
Sep 26 2020, 03:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,114 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California
given the caliber of 914 stewardship here, i kind of already know...
i'm in the midst of installing a "new to me" 1.7. not intended to be the "end all, be all" powertrain, this is more of a "tide me over" until i do my long intended small block conversion. as expected, i'm doing a lot of "while i'm in there..." work. after taking a wire wheel to my battery tray and hell hole, there's more of "less" in the former, while the later is still solid. battery tray support is also still solid. tray itself feels solid, i've been using it as a step to get in and out of the engine bay to do things like body to motor mount bar brackest, upgrade firewall shifter bushing, fuel lines (while i'm in there stuff) etc... is replacing the battery tray an "i can't believe you haven't done this already?!", or can i put it off a few more years (until the engine upgrade) with rust treatment? the car will almost never see rain, will be driven very occasionally and lives in a garage. anybody have a battery go "walkabout" while driving due to such a tray? if i'm convinced i should replaced the battery tray now, what's a ballpark figure for that welding job? i have a few friends that weld but, it's a bit more of a favor than i'm comfortable asking, unless my favor balance was well into the black... these particular friends have already helped me way more than i've been able to help them, my conscience dictates monetary payment. |
| Superhawk996 |
Sep 27 2020, 08:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,163 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Not sure if it is just shadowing but I think I see two small black pinholes on the firewall (left side in the hell hole pocket).
![]() Check carefully. When pinholes start here, they allow water to enter the cabin. That in turn leads to floorpan rust inside the cabin. If there are pinholes, I wouln't get into deep metal work at this point. Clean, neutralize with Ospho or similar, cover with seam sealer, paint to match. |
| pt_700 |
Sep 27 2020, 11:25 AM
thankfully superhawk, those are just shadows, it's all still solid.
thanks all for convincing me to do right by my 914. i'll order a tray and have reached out to an old friend who has a welding business to see if he is (or knows somebody) who could use a little job. Not sure if it is just shadowing but I think I see two small black pinholes on the firewall (left side in the hell hole pocket). ![]() Check carefully. When pinholes start here, they allow water to enter the cabin. That in turn leads to floorpan rust inside the cabin. If there are pinholes, I wouln't get into deep metal work at this point. Clean, neutralize with Ospho or similar, cover with seam sealer, paint to match. |
| ndfrigi |
Sep 27 2020, 01:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,995 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
thankfully superhawk, those are just shadows, it's all still solid. thanks all for convincing me to do right by my 914. i'll order a tray and have reached out to an old friend who has a welding business to see if he is (or knows somebody) who could use a little job. Not sure if it is just shadowing but I think I see two small black pinholes on the firewall (left side in the hell hole pocket). ![]() Check carefully. When pinholes start here, they allow water to enter the cabin. That in turn leads to floorpan rust inside the cabin. If there are pinholes, I wouln't get into deep metal work at this point. Clean, neutralize with Ospho or similar, cover with seam sealer, paint to match. For battery tray, I think Jeffery ( @914_7T3 ) has one for sale. |
pt_700 my battery tray and hell hole Sep 26 2020, 03:18 PM
914Sixer Really nice, simple battery tray replacement. :b... Sep 26 2020, 05:56 PM
BillC I would replace the battery tray, especially while... Sep 26 2020, 07:22 PM
Coondog Consider yourself lucky....... :first: Sep 26 2020, 07:27 PM
bkrantz One other option: surgically remove the old tray, ... Sep 26 2020, 08:32 PM
cary Be careful removing / detaching tray from the wall... Sep 26 2020, 10:28 PM
Tdskip Are you sure those are shadows? Think @superhawk9... Sep 27 2020, 11:28 AM
rjames Like others have said, just remove the battery tra... Sep 27 2020, 11:39 AM
VaccaRabite Just get the part from Restoration Design.
The pa... Sep 27 2020, 06:35 PM
pt_700 tray's been ordered from restoration designs.
... Sep 27 2020, 10:37 PM
Tdskip
tray's been ordered from restoration designs.... Sep 30 2020, 07:03 AM
ctc911ctc You have no idea how lucky you are! Sep 29 2020, 03:25 PM
Frankvw in case you are going for the 'top-tray-only... Sep 30 2020, 12:51 AM
malcolm2 My 2 cents on the rust.... Some people like the s... Sep 30 2020, 07:13 AM
rjames
My 2 cents on the rust.... Some people like the ... Sep 30 2020, 10:15 AM
Superhawk996 I'd love for that hell hole to have been my st... Sep 30 2020, 08:34 AM
mlindner Last replace with a gel battery/ non-acid. Sep 30 2020, 10:18 AM
sholman5
Instead of welding the tray and support in place... Sep 30 2020, 10:30 AM
pt_700 i'm liking the idea of a bolt in tray and or s... Sep 30 2020, 11:39 AM
Frankvw wow, great result to show for !!!... Sep 30 2020, 11:45 AM
sholman5
i'm liking the idea of a bolt in tray and or ... Sep 30 2020, 02:52 PM
Frankvw Yes that helps !!
"For the tray I use... Oct 1 2020, 04:12 AM
pt_700 so, you can't get behind where you bolted the ... Oct 1 2020, 10:08 PM
mtndawg I’ve done a bolt down battery tray in 2 cars. Lo... Oct 1 2020, 10:36 PM
pt_700 nutsert is one of the products (rivetnuts too). l... Oct 6 2020, 12:11 PM
pt_700 finally some progress on this, intervening was the... Oct 16 2020, 09:59 PM
Superhawk996 Glad to see you're getting after it and that t... Oct 17 2020, 06:53 AM
Tdskip
Glad to see you're getting after it and that ... Oct 17 2020, 07:21 AM
mlindner PT 700, using revnuts...make sure they fit very ti... Oct 17 2020, 08:05 AM
pt_700 thanks for the tips! i'll get back in the... Oct 17 2020, 11:25 AM
pt_700 one small step forward, two steps back... not une... Oct 18 2020, 10:51 PM
Superhawk996
having seen much worse repaired here, i know i... Oct 19 2020, 06:27 AM
sholman5 Last picture. It is a drain for any moisture that ... Oct 19 2020, 03:09 AM
pt_700 thanks gents! at the time i discovered that i... Oct 19 2020, 08:18 AM
pt_700 took a few weeks off from the 914 while working on... Nov 6 2020, 06:30 PM
seanpaulmc Thank you for posting this. Love seeing the tools... Nov 6 2020, 07:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 06:55 PM |
