Weird shift coupler issue |
Tdskip |
Sep 23 2020, 04:08 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Well this is a first-the shift coupler won’t fit onto the rod that connects the coupler to the shifter.
Do I need to just wire brush the rod that comes out through the opening in the firewall to make sure that there’s no scale on it? I can’t feel anything hanging it up with my fingers. Anyone ever had this happen to them? |
IronHillRestorations |
Sep 25 2020, 09:09 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler.
Tdskip |
Sep 26 2020, 06:08 AM
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler. Good morning, wow, those must have been pretty bent. I’m planning on connecting the shifter today so I’ll soon find out if I have an issue there. Thanks for the response, hope you are doing well. EDIT - turns out I did have a burr on the end as you all suggested, and once I took the Dremel to it problem solved. Everything is back and connected. Weird that this piece was nicked and generally beat up, maybe the last person working on it had an anger management problem? |
forrestkhaag |
Sep 27 2020, 01:24 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I've seen rear bars that got bent enough to have trouble fully engaging at the coupler. Good morning, wow, those must have been pretty bent. I’m planning on connecting the shifter today so I’ll soon find out if I have an issue there. Thanks for the response, hope you are doing well. EDIT - turns out I did have a burr on the end as you all suggested, and once I took the Dremel to it problem solved. Everything is back and connected. Weird that this piece was nicked and generally beat up, maybe the last person working on it had an anger management problem? Pleas let us know how your subsequent linkage adjustment goes..... I remain a three gear guy for now but at 4K, the six is sailing along above most posted speed limits in our small town.... (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 11:16 AM |
