Starting my engine on a stand, issues arose |
malcolm2 |
Sep 29 2020, 06:16 AM
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
malcolm2 |
Sep 29 2020, 09:16 AM
I hear music in the back ground. You Tube may shut me down for no license. But for now.... Here is a vid of generating Oil Pressure. Finally something that did not cause me issues. (IMG:style_emoticons/default/piratenanner.gif)
Oil Pressure build up Video https://www.youtube.com/watch?v=h2xtp-eEDQ0 |
VaccaRabite |
Sep 29 2020, 09:36 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I hear music in the back ground. You Tube may shut me down for no license. But for now.... Here is a vid of generating Oil Pressure. Finally something that did not cause me issues. (IMG:style_emoticons/default/piratenanner.gif) Oil Pressure build up Video https://www.youtube.com/watch?v=h2xtp-eEDQ0 Your video is marked private Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:17 AM |
