> Starting my engine on a stand, issues arose
malcolm2
post Sep 29 2020, 06:16 AM
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil.
I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too.
After a few tries, she started. As expected running very ruff. Back-firing thru the carbs.
I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper.
I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs.
I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped.
I have a note in to my distributor vendor about how this "rev limiter" on this module works.
So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions?
malcolm2
post Sep 29 2020, 09:16 AM
I hear music in the back ground. You Tube may shut me down for no license. But for now.... Here is a vid of generating Oil Pressure. Finally something that did not cause me issues. (IMG:style_emoticons/default/piratenanner.gif)
Oil Pressure build up Video
https://www.youtube.com/watch?v=h2xtp-eEDQ0
VaccaRabite
post Sep 29 2020, 09:36 AM
En Garde!
QUOTE(malcolm2 @ Sep 29 2020, 11:16 AM) *
Your video is marked private
Zach
malcolm2
post Sep 29 2020, 10:44 AM
QUOTE(VaccaRabite @ Sep 29 2020, 10:36 AM) *
Zach
Thanks. I have marked Public.
malcolm2   Starting my engine on a stand   Sep 29 2020, 06:16 AM
Mark Henry   Do you have a snail sync tool? Sounds like a sync ...   Sep 29 2020, 06:53 AM
malcolm2   Do you have a snail sync tool? Sounds like a sync...   Sep 29 2020, 08:50 AM
Mark Henry   [quote name='Mark Henry' post='2855198' date='Sep...   Sep 29 2020, 09:17 AM
VaccaRabite   First off: :ttiwwp: We need pic of your engine ...   Sep 29 2020, 06:58 AM
malcolm2   I hear music in the back ground. You Tube may shu...   Sep 29 2020, 09:16 AM
VaccaRabite   I hear music in the back ground. You Tube may sh...   Sep 29 2020, 09:36 AM
malcolm2   Your video is marked private Zach Thanks. I ...   Sep 29 2020, 10:44 AM
rhodyguy   Depending on the idle speed adjustment screws to b...   Sep 29 2020, 10:31 AM
malcolm2   Is this all there is to it? Just test or measure ...   Sep 29 2020, 10:54 AM
Mark Henry   Is this all there is to it? Just test or measure...   Sep 29 2020, 01:41 PM
rhodyguy   The number values on the tool are sort of irreleva...   Sep 29 2020, 11:04 AM
IronHillRestorations   Here's my carb tuning procedure from a March 0...   Sep 29 2020, 01:12 PM
Superhawk996   Assumptions: the carbs have the optimum jet and ...   Sep 29 2020, 01:26 PM
914Toy   Here's my carb tuning procedure from a March ...   Sep 30 2020, 12:33 PM
IronHillRestorations   I'll add that if your linkage moves at all whe...   Sep 29 2020, 01:14 PM
IronHillRestorations   Where in Nashville are you? I'm coming throug...   Sep 29 2020, 01:22 PM
malcolm2   Where in Nashville are you? I'm coming throu...   Sep 29 2020, 01:58 PM
Superhawk996   @mark henry Curious if you have used a Uni-Syn. ...   Sep 29 2020, 01:57 PM
malcolm2   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 29 2020, 04:22 PM
Superhawk996   That Uni-SYn looks totally different. Does it ...   Sep 29 2020, 05:02 PM
IronHillRestorations   [b]@[url=http://www.914world.com/bbs2/index.php?...   Sep 30 2020, 11:06 AM
porschetub   [quote name='malcolm2' post='2855370' date='Sep 2...   Sep 30 2020, 01:48 PM
Superhawk996   [quote name='malcolm2' post='2855370' date='Sep ...   Oct 1 2020, 05:44 AM
flyer86d   Pull out each idle jet and make sure one is not cl...   Sep 29 2020, 02:48 PM
thelogo   Sorry but to encourage this is irresponsible The...   Sep 29 2020, 03:39 PM
Superhawk996   Sorry but to encourage this is irresponsible Y...   Sep 29 2020, 04:58 PM
thelogo   Sorry but to encourage this is irresponsible ...   Sep 29 2020, 07:49 PM
malcolm2   [quote name='Superhawk996' post='2855376' date='S...   Sep 29 2020, 08:01 PM
thelogo   Sorry but to encourage this is irresponsible ...   Sep 30 2020, 12:36 AM
Mark Henry   I've used both uni-sync and the snail (STE), I...   Sep 30 2020, 03:10 AM
nditiz1   Do yourself a favor and get the german STE, especi...   Sep 30 2020, 04:23 AM
ri914   Lots of great info from the 914 experts. I love re...   Sep 30 2020, 11:16 AM
malcolm2   I got the snail version on the way. I just pulled...   Sep 30 2020, 11:21 AM
malcolm2   Any ideas on where to find the bushing. I found on...   Sep 30 2020, 11:25 AM
nditiz1   You might be able to combo ship with other things ...   Sep 30 2020, 12:32 PM
malcolm2   So with the linkage off, there is no choice but to...   Sep 30 2020, 12:50 PM
nditiz1   No need for rev here unless you are setting the ti...   Sep 30 2020, 01:49 PM
ndfrigi   @malcom2 check the ff link to give you more idea ...   Oct 1 2020, 10:26 AM
nditiz1   What size engine are those on? @[url=http://www.9...   Oct 1 2020, 11:23 AM
ndfrigi   What size engine are those on? @[url=http://www....   Oct 1 2020, 12:19 PM
IronHillRestorations   My plans have changed. Would late Sunday afternoon...   Oct 1 2020, 11:34 AM
malcolm2   My plans have changed. Would late Sunday afternoo...   Oct 1 2020, 01:22 PM
malcolm2   I am back at it after a Fall Break with the wife. ...   Oct 10 2020, 11:56 AM
Gint   I am back at it after a Fall Break with the wife....   Oct 11 2020, 08:49 AM
malcolm2   Linkage bushing - Check your local hardware sto...   Oct 11 2020, 12:24 PM
rhodyguy   Do your carbs not have velocity stacks? You can us...   Oct 10 2020, 12:05 PM
bobboinski   I know it is too late but back when I was riding m...   Oct 10 2020, 06:28 PM
Gint   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 11 2020, 08:56 AM
malcolm2   I love when a plan comes together..... Well almost...   Oct 11 2020, 12:06 PM
malcolm2   Linkage is still wacky, but I got it DONE. 1.8 li...   Oct 11 2020, 12:19 PM
jtprettyman   Linkage is still wacky, but I got it DONE. 1.8 l...   Oct 11 2020, 01:22 PM
Gint   Not necessarily. The entire thing operates as a u...   Oct 11 2020, 12:31 PM
Superhawk996   Great Job! :Qarl: Love the cacophony of a...   Oct 11 2020, 01:06 PM
IronHillRestorations   I've seen it with springs on both sides, and s...   Oct 11 2020, 09:32 PM
- Lo-Fi Version Time is now: 22nd September 2025 - 11:28 PM
