malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,870 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Where in Nashville are you? I'm coming through Friday on my way to east TN (Cleveland). If it's not too out of the way and my week doesn't go to hell, I might be able to stop by for a little bit.
malcolm2 |
Where in Nashville are you? I'm coming through Friday on my way to east TN (Cleveland). If it's not too out of the way and my week doesn't go to hell, I might be able to stop by for a little bit. East of town couple exits past the airport on I-40. Mount Juliet. You will probably head south (east) down 24 towards Chattanooga. But Cleveland can be reached taking 40 east most of the way. keep me posted. Clark |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:28 PM |
