> Starting my engine on a stand, issues arose
malcolm2
post Sep 29 2020, 06:16 AM
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil.
I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too.
After a few tries, she started. As expected running very ruff. Back-firing thru the carbs.
I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper.
I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs.
I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped.
I have a note in to my distributor vendor about how this "rev limiter" on this module works.
So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions?
flyer86d
post Sep 29 2020, 02:48 PM
Pull out each idle jet and make sure one is not clogged. Weber’s require clean fuel and very small particles will clog the idle jets. Also, Weber’s run about halfway thru the RPM range on the idle circuit. If it is rough at idle but smoth at full throttle, I’d look at the idle circuit.
Charlie
malcolm2   Starting my engine on a stand   Sep 29 2020, 06:16 AM
Mark Henry   Do you have a snail sync tool? Sounds like a sync ...   Sep 29 2020, 06:53 AM
malcolm2   Do you have a snail sync tool? Sounds like a sync...   Sep 29 2020, 08:50 AM
Mark Henry   [quote name='Mark Henry' post='2855198' date='Sep...   Sep 29 2020, 09:17 AM
VaccaRabite   First off: :ttiwwp: We need pic of your engine ...   Sep 29 2020, 06:58 AM
malcolm2   I hear music in the back ground. You Tube may shu...   Sep 29 2020, 09:16 AM
VaccaRabite   I hear music in the back ground. You Tube may sh...   Sep 29 2020, 09:36 AM
malcolm2   Your video is marked private Zach Thanks. I ...   Sep 29 2020, 10:44 AM
rhodyguy   Depending on the idle speed adjustment screws to b...   Sep 29 2020, 10:31 AM
malcolm2   Is this all there is to it? Just test or measure ...   Sep 29 2020, 10:54 AM
Mark Henry   Is this all there is to it? Just test or measure...   Sep 29 2020, 01:41 PM
rhodyguy   The number values on the tool are sort of irreleva...   Sep 29 2020, 11:04 AM
IronHillRestorations   Here's my carb tuning procedure from a March 0...   Sep 29 2020, 01:12 PM
Superhawk996   Assumptions: the carbs have the optimum jet and ...   Sep 29 2020, 01:26 PM
914Toy   Here's my carb tuning procedure from a March ...   Sep 30 2020, 12:33 PM
IronHillRestorations   I'll add that if your linkage moves at all whe...   Sep 29 2020, 01:14 PM
IronHillRestorations   Where in Nashville are you? I'm coming throug...   Sep 29 2020, 01:22 PM
malcolm2   Where in Nashville are you? I'm coming throu...   Sep 29 2020, 01:58 PM
Superhawk996   @mark henry Curious if you have used a Uni-Syn. ...   Sep 29 2020, 01:57 PM
malcolm2   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 29 2020, 04:22 PM
Superhawk996   That Uni-SYn looks totally different. Does it ...   Sep 29 2020, 05:02 PM
IronHillRestorations   [b]@[url=http://www.914world.com/bbs2/index.php?...   Sep 30 2020, 11:06 AM
porschetub   [quote name='malcolm2' post='2855370' date='Sep 2...   Sep 30 2020, 01:48 PM
Superhawk996   [quote name='malcolm2' post='2855370' date='Sep ...   Oct 1 2020, 05:44 AM
flyer86d   Pull out each idle jet and make sure one is not cl...   Sep 29 2020, 02:48 PM
thelogo   Sorry but to encourage this is irresponsible The...   Sep 29 2020, 03:39 PM
Superhawk996   Sorry but to encourage this is irresponsible Y...   Sep 29 2020, 04:58 PM
thelogo   Sorry but to encourage this is irresponsible ...   Sep 29 2020, 07:49 PM
malcolm2   [quote name='Superhawk996' post='2855376' date='S...   Sep 29 2020, 08:01 PM
thelogo   Sorry but to encourage this is irresponsible ...   Sep 30 2020, 12:36 AM
Mark Henry   I've used both uni-sync and the snail (STE), I...   Sep 30 2020, 03:10 AM
nditiz1   Do yourself a favor and get the german STE, especi...   Sep 30 2020, 04:23 AM
ri914   Lots of great info from the 914 experts. I love re...   Sep 30 2020, 11:16 AM
malcolm2   I got the snail version on the way. I just pulled...   Sep 30 2020, 11:21 AM
malcolm2   Any ideas on where to find the bushing. I found on...   Sep 30 2020, 11:25 AM
nditiz1   You might be able to combo ship with other things ...   Sep 30 2020, 12:32 PM
malcolm2   So with the linkage off, there is no choice but to...   Sep 30 2020, 12:50 PM
nditiz1   No need for rev here unless you are setting the ti...   Sep 30 2020, 01:49 PM
ndfrigi   @malcom2 check the ff link to give you more idea ...   Oct 1 2020, 10:26 AM
nditiz1   What size engine are those on? @[url=http://www.9...   Oct 1 2020, 11:23 AM
ndfrigi   What size engine are those on? @[url=http://www....   Oct 1 2020, 12:19 PM
IronHillRestorations   My plans have changed. Would late Sunday afternoon...   Oct 1 2020, 11:34 AM
malcolm2   My plans have changed. Would late Sunday afternoo...   Oct 1 2020, 01:22 PM
malcolm2   I am back at it after a Fall Break with the wife. ...   Oct 10 2020, 11:56 AM
Gint   I am back at it after a Fall Break with the wife....   Oct 11 2020, 08:49 AM
malcolm2   Linkage bushing - Check your local hardware sto...   Oct 11 2020, 12:24 PM
rhodyguy   Do your carbs not have velocity stacks? You can us...   Oct 10 2020, 12:05 PM
bobboinski   I know it is too late but back when I was riding m...   Oct 10 2020, 06:28 PM
Gint   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 11 2020, 08:56 AM
malcolm2   I love when a plan comes together..... Well almost...   Oct 11 2020, 12:06 PM
malcolm2   Linkage is still wacky, but I got it DONE. 1.8 li...   Oct 11 2020, 12:19 PM
jtprettyman   Linkage is still wacky, but I got it DONE. 1.8 l...   Oct 11 2020, 01:22 PM
Gint   Not necessarily. The entire thing operates as a u...   Oct 11 2020, 12:31 PM
Superhawk996   Great Job! :Qarl: Love the cacophony of a...   Oct 11 2020, 01:06 PM
IronHillRestorations   I've seen it with springs on both sides, and s...   Oct 11 2020, 09:32 PM
- Lo-Fi Version Time is now: 22nd September 2025 - 11:28 PM
