Starting my engine on a stand, issues arose |
malcolm2 |
Sep 29 2020, 06:16 AM
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
Mark Henry |
Sep 30 2020, 03:10 AM
I've used both uni-sync and the snail (STE), I prefer the snail. That said I only used the uni-sync once back in the mid 90', didn't really like it, It didn't work on weber DCNF carbs, so I sold it in short order and bought a STE snail. For other cars the snail is more adaptable, mostly using simple plastic cups, that's how I do Solex Kadrons.
The cheap china snail is OK for the home shop use, but be careful with it, as it won't take the abuse of even semi-pro garage operation. Although I do read his posts from time to time there's a reason I have one and only one member on ignore. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:16 AM |
