Starting my engine on a stand, issues arose |
malcolm2 |
Sep 29 2020, 06:16 AM
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
nditiz1 |
Sep 30 2020, 04:23 AM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Do yourself a favor and get the german STE, especially if you are going to stick with carbs. It is the one tool you will use over and over again.
Perry's mini guide is a pretty good baseline. Since we don't know the condition of these carbs it is very difficult to help diagnose the issue. If the jets are clogged you could experience some of the symptoms you have expressed. I have even seen the same rev drops on a single 34PICT-3 (Beetle carb)while trying to tune it. Pull the carbs off, take them apart and soak them in some carb cleaner. They sell a 1 gallon can that it can fit into. Buy some carb kits from aircooled.net or another well known site. Don't skimp on the rebuild kits, get a good kit. Follow the setup guides to get the floats set properly in both carbs. Set the baselines and throw them on. You would be surprised how carbs just a little dirty can really make an engine run rough vs them being a little out of tune. Also, you can run an engine, and technically drive an engine without having the main stacks installed. Give it to much throttle and it will choke the engine as the mains will start to kick in. This is also a great way to test you have the correct idle jets installed. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:44 AM |
