Medtner3 |
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None ![]() |
Just rebuilt my rear calipers with seals from PMB Performance. Using a vacuum brake bleeder I started with the right rear caliper lower bleeder screw ( I have two screws) and initially pulled about an inch of brake fluid with lots of bubbles and then zip. I get zero brake fluid now.
What could cause this? I have no signs of any leaks and the brakes were not bad before I rebuilt the calipers. I read somewhere that I might need to bleed the proportioning valve or even pump into the caliper some brake fluid through the top bleeder ? I ordered a Motive pressure bleeder which arrives in a few days Attached image(s) ![]() ![]() ![]() |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Chances are the brake fluid drained out of the master cylinder. I had that, had to pressurize the fluid reservoir and have someone pump the brake at the same time. Problem solved. Maybe try it on the front calipper first just to take the proportion valve out of the mix. Best, Mark
Lo-Fi Version | Time is now: 1st August 2025 - 02:11 PM |
