Medtner3 |
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None ![]() |
Just rebuilt my rear calipers with seals from PMB Performance. Using a vacuum brake bleeder I started with the right rear caliper lower bleeder screw ( I have two screws) and initially pulled about an inch of brake fluid with lots of bubbles and then zip. I get zero brake fluid now.
What could cause this? I have no signs of any leaks and the brakes were not bad before I rebuilt the calipers. I read somewhere that I might need to bleed the proportioning valve or even pump into the caliper some brake fluid through the top bleeder ? I ordered a Motive pressure bleeder which arrives in a few days Attached image(s) ![]() ![]() ![]() |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,567 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
I like to use pressure (motive @ 5-10 psi) followed by pedal bleeding. You can also replace the bleed screws with speed bleeders to make things a one-person job. Some people say you shouldn't use speed bleeders with the motive, but it's worked fine for me. Here are two videos which may help as well...
"Bench bleeding" master cylinder while in the car: https://youtu.be/OOSer774NqM Bleeding brakes: https://youtu.be/ymHHD6uKhfc |
Lo-Fi Version | Time is now: 1st August 2025 - 01:54 PM |
