mottress |
Newbie ![]() Group: Members Posts: 1 Joined: 4-September 20 From: Grants Pass, OR Member No.: 24,661 Region Association: Pacific Northwest ![]() |
Hey folks,
I just inherited my dad's '71 914/4 1.7L, and I'm having a (typical?) litany of problems that I would love some advice about. I was able to transport the car from my aunt's house in Nashville to Southern Oregon where I live. It was "running fine" before I got it and was able to drive it from the auto transporter's dealership ~0.5 mile home, but when I tried to take it out for a jaunt later that afternoon, it idled out at the closest stop sign. Turns out my aunt hadn't put any gas in it in a year and the tank was bone dry. It was a miracle of God that I was able to get it home. I filled up the tank with ethanol-free premium and tried to get it to start, but the car would only turn over. Since then I've been interrogating every aspect of the car from the fuel lines to the electrical, and I've come to the following conclusions using my voltmeter and other tools: 1. The empty tank killed the recently-installed rebuilt fuel pump 2. The relays and relay board are in good condition after a thorough cleaning of the connections and fuses. There are no broken connections. 3. There wires to the fuel pump are intact. 3. The Power Relay turns on when I turn the key to "On", but the Fuel Pump relay does not click on. I've narrowed this down to there being a faulty ground at the Fuel Pump relay (i.e. point 85), as I have voltage on both point 86 and 30. Point 85 connects to the III connector which in turn connects to the Control Unit. These wires are intact. So my question is: Is it likely that a faulty ground in the Control Unit is causing the Fuel Pump relay not to activate, or am I missing something? I've traced all the wires in the wiring diagrams and it seems to me that the Control Unit has it's own ground, but I'm not sure how to check that. Has anyone else seen this problem before? Also, it seems odd/conspicuous that I would have a fuel pump failure AND some new electrical issue with the fuel pump relay at the same time. I'm a novice to the car so even basic advice is welcomed. Tom |
Lo-Fi Version | Time is now: 19th July 2025 - 10:30 PM |
