Medtner3 |
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None ![]() |
Just rebuilt my rear calipers with seals from PMB Performance. Using a vacuum brake bleeder I started with the right rear caliper lower bleeder screw ( I have two screws) and initially pulled about an inch of brake fluid with lots of bubbles and then zip. I get zero brake fluid now.
What could cause this? I have no signs of any leaks and the brakes were not bad before I rebuilt the calipers. I read somewhere that I might need to bleed the proportioning valve or even pump into the caliper some brake fluid through the top bleeder ? I ordered a Motive pressure bleeder which arrives in a few days Attached image(s) ![]() ![]() ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,300 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Have you correctly set the venting clearance on the rear calipers? IIRC, the correct value is half of the value printed in the books.
Medtner3 |
Lo-Fi Version | Time is now: 1st August 2025 - 02:12 PM |
