> Overfilled the transmission
AZBanks
post Jun 15 2020, 01:25 PM
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals??
AZBanks
post Oct 9 2020, 01:21 AM
The trans was leaking out of the input shaft seal.
How do you get the input shaft seal out of the front of the transmission?
ndfrigi
post Oct 9 2020, 09:50 AM
QUOTE(AZBanks @ Oct 9 2020, 12:21 AM) *
where do you see the fluid? if coming on the bottom middle hole between transmission and engine, probably the rear main seal is the one leaking with engine oil since you also mentioned just a few drops after driving. Just another item to check also.
AZBanks   Overfilled the transmission   Jun 15 2020, 01:25 PM
911GT2   I installed a replacement transmission in the 71....   Jun 15 2020, 01:29 PM
Frankvw   just take out the fillplug and let the surplus com...   Jun 15 2020, 01:30 PM
GregAmy   I'm not sure how it's possible to overfill...   Jun 15 2020, 01:44 PM
AZBanks   I'm not sure how it's possible to overfil...   Jun 15 2020, 02:21 PM
GregAmy   I suppose it's possible that, with only ...   Jun 15 2020, 03:16 PM
Tdskip   I suppose it's possible that, with only ...   Jun 15 2020, 04:29 PM
porschetub   Also make sure the top vent is clear....it could b...   Jun 15 2020, 04:11 PM
PlaysWithCars   Also make sure the top vent is clear....it could ...   Jun 15 2020, 10:46 PM
AZBanks   The trans was leaking out of the input shaft seal....   Oct 9 2020, 01:21 AM
Tdskip   The trans was leaking out of the input shaft seal...   Oct 9 2020, 06:07 AM
ndfrigi   The trans was leaking out of the input shaft seal...   Oct 9 2020, 09:50 AM
AZBanks   Thanks for the suggestions. It is the old seals ...   Oct 9 2020, 07:25 PM
ndfrigi   Are you draining the gear oil? I don’t you need ...   Oct 9 2020, 07:36 PM
AZBanks   Dr. Evil said not to use Swepco, He says the best ...   Oct 9 2020, 07:45 PM
iankarr   Try putting a screw or two into the old seal to gi...   Oct 9 2020, 07:50 PM
AZBanks   I bought a cheap harbor freight seal puller. It wo...   Oct 9 2020, 10:51 PM
AZBanks   In my "front engine 914" thread I docume...   Oct 17 2020, 08:14 PM
mrholland2   In my "front engine 914" thread I docum...   Oct 20 2020, 09:39 AM
AZBanks   In my "front engine 914" thread I docu...   Oct 20 2020, 11:25 AM
michael7810   I had similar experience getting mine thru emissio...   Oct 18 2020, 07:36 AM
AZBanks   Arizona has seriously messed up classic car regist...   Oct 19 2020, 02:00 AM
bandjoey   Just and FYI on insurance Haggerty never asked...   Oct 19 2020, 11:37 PM
AZBanks   Just and FYI on insurance Haggerty never aske...   Oct 20 2020, 02:25 AM
AZBanks   Just and FYI on insurance Haggerty never aske...   Dec 7 2020, 05:47 PM
914e   Just and FYI on insurance Haggerty never ask...   Dec 7 2020, 10:30 PM
AZBanks   Since the exhaust is off while the trans is out, I...   Oct 20 2020, 02:28 AM
AZBanks   Nothing like a professional wrap job.   Oct 20 2020, 02:30 AM
AZBanks   Yeah, really, this is NOTHING like a professional ...   Oct 20 2020, 02:31 AM
VaccaRabite   Why did you wrap it? That wrap holds oil and greas...   Oct 20 2020, 07:27 AM
AZBanks   Why did you wrap it? That wrap holds oil and grea...   Oct 20 2020, 01:47 PM
AZBanks   I got the trans back in the car and everything els...   Nov 1 2020, 01:12 AM
VaccaRabite   Yeah collector car insurance wants each driver to ...   Dec 8 2020, 12:16 PM
AZBanks   I get their reasoning for most people but not ever...   Dec 9 2020, 03:38 PM
- Lo-Fi Version Time is now: 22nd June 2026 - 11:00 PM
