> State of rust and unknown plastic bit
macnichol
post Oct 9 2020, 04:47 PM
Hi all, thought'd I'd share my continuing progress on my college 914 project. I was able to get a better look underneath the car and poked around with a screwdriver, the rust looks to be mostly surface. I got the calipers off, they are def worn out and need a rebuild.
My question to you guys, is that crack in the long something that I need to be especially worried about and is it a good fix to remove the rust and patch it up with the TIG? Also, what's that plastic piece hanging from the underbelly of the car? Thanks guys Attached Image Attached ImageAttached Image Attached Image
dlee6204
post Oct 9 2020, 06:06 PM
Howdy
Your long is not original. It's likely someone did a sub-par repair and didn't completely fix the previous rust issues. It looks like the the crack is the full height of the long? If so its likely the chassis flexing so yes it should be an area of concern. I recommend inspecting this area further to determine a course of action.
And the plastic piece hanging down is a cover that protects the shift linkage connection just outside the tunnel.
macnichol
post Oct 9 2020, 08:09 PM
QUOTE(dlee6204 @ Oct 9 2020, 06:06 PM) *
Are quality aftermarket longs available? I've found the ones on restoration-design but it seems to only be the inner longs. I supposed it would be possible to fabricate a solution but I'd not want to go this route if possible. At some point I certainly would like to remove the non-original repair work but as of right now, I only have a rented garage to work in so it's a little tough.
If the chassis is structurally sound, would it be advisable to do some rust removal, weld the crack closed and add a patch panel overtop? It looks like it was poorly welded to begin with and ended up breaking.
Tdskip
post Oct 10 2020, 07:27 AM
QUOTE(macnichol @ Oct 9 2020, 09:09 PM) *
How are your door gaps? Nice and even still on both sides or a bit tighter in the top near the door handles?
- Lo-Fi Version Time is now: 2nd April 2026 - 04:41 PM
