malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
bobboinski |
Member ![]() ![]() Group: Members Posts: 200 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California ![]() ![]() |
I know it is too late but back when I was riding motorcycles I used something like this to balance the carburetors on my Z1. It was nice because when you adjusted one carb it affected the others and you could see everything that was happening. You need a port to attach the gauges to each intake run so maybe that is why they aren't used on 914s.
https://www.motosport.com/product/?acctid=2...001&variant[MOP000W]=MOP000W-X001-Y001 |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:26 PM |
