malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,104 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
@malcolm2
Here you go. I knew there were more fittings available for the STE https://www.carburetion.com/Products/Produc...spx?part=STE-SK |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:28 PM |
