Starting my engine on a stand, issues arose |
malcolm2 |
Sep 29 2020, 06:16 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have built a fresh 2.0 and borrowed a set of weber 40s to get her running, broken-in etc....
I bought a new single vacuum distributor with the flame thrower 3 module inside. Also bought the Petronix coil. I built up oil pressure, then connected the gas lines, fuel pump, and coil. Tach and timing light too. After a few tries, she started. As expected running very ruff. Back-firing thru the carbs. I loosened the distributor and tried to make some adjustments. That seemed to help the back-firing a bit, but not totally. I got the idle timing to what looks like 7 btdc, but it is tuff to work everything without a helper. I know next to nothing about these carbs, and about the same amount to tune them enough to bench run the engine, but I am looking into that. Any help would be appreciated on the carbs. I got it idling, again, very ruff. So I wanted to do the cam break in, so I rev'd it up to about 3000 and held there. Maybe a minute and the revs dropped and I had to putz with the accelerator to keep her going. Again up to 3000, same thing revs dropped. I have a note in to my distributor vendor about how this "rev limiter" on this module works. So three things here. She is still running ruff, back-firing etc...and there is the high rev cut-off. Lastly the carbs, any quick checks or adjustments there? Any thoughts or suggestions? |
malcolm2 |
Oct 11 2020, 12:19 PM
Linkage is still wacky, but I got it DONE. 1.8 liter out of a 914, converted to a 2.0 liter, with Camper Special Heads, swivel foot adjusters, solid rocker spacers, chromoly push rods, 9550 cam, flamer thrower 3 module and coil, Stock exhaust, dished bus pistons, 7.4 CR for my VW BUS, borrowed weber 40s ( IIRC ) for break-in.
Some may remember my 1911 for my 914.... I screwed that up for sure. Miss-indexed the cam and the crank.... (IMG:style_emoticons/default/blink.gif) never started, had to crack it open and there is was. That one has 50,000 miles on it now. (IMG:style_emoticons/default/driving-girl.gif) Thanks to all that got me this far and thru that mess. here is the finished product. https://www.youtube.com/watch?v=bpr5DZUQ4pM https://youtu.be/bpr5DZUQ4pM |
jtprettyman |
Oct 11 2020, 01:22 PM
Rust Bucket Owner Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States |
Linkage is still wacky, but I got it DONE. 1.8 liter out of a 914, converted to a 2.0 liter, with Camper Special Heads, swivel foot adjusters, solid rocker spacers, chromoly push rods, 9550 cam, flamer thrower 3 module and coil, Stock exhaust, dished bus pistons, 7.4 CR for my VW BUS, borrowed weber 40s ( IIRC ) for break-in. Some may remember my 1911 for my 914.... I screwed that up for sure. Miss-indexed the cam and the crank.... (IMG:style_emoticons/default/blink.gif) never started, had to crack it open and there is was. That one has 50,000 miles on it now. (IMG:style_emoticons/default/driving-girl.gif) Thanks to all that got me this far and thru that mess. here is the finished product. https://www.youtube.com/watch?v=bpr5DZUQ4pM https://youtu.be/bpr5DZUQ4pM @malcolm2 - Those were 44's. Sounds great, very nice grumble to it. (IMG:style_emoticons/default/sunglasses.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:57 PM |
