> Worst nightmare or just fine?
macnichol
post Oct 15 2020, 08:12 PM
I pulled the oil metal mesh basket today and I was a little panicked to see that it looked like this. The metal center where the the bolt goes thru looks deformed to me, is that normal? The mesh itself I had to crush a bit removing from the metal plate and I used a new one. I'm praying that the previous owner did *not* over torque that bolt, how can I tell if this is the case? Also, how do you guys remove rounded bolts? The oil drain plug is near impossible to get off with the state it's in right now. Attached Image Attached Image
barefoot
post Oct 16 2020, 06:48 AM
Be careful that the screen center is not deformed upward. When building my engine, it would not build oil pressure, the center had blocked the oil pick- up tube, fixed that then OK.
- Lo-Fi Version Time is now: 2nd April 2026 - 01:08 PM
