| 914Sixer |
May 2 2018, 05:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,557 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
You need the Saab fuel gauge and an early 914 fuel gauge with the round black plugs on it. Take the Saab fuel gauge apart starting with the ring and face. Go around back and remove the 3 screws. Drop gauge out the front. Take a small fork and gently pull up on the needle. Take two screw off dial face. They are VERY SMALL. Turn assembly over and undo the two ground nuts and plug. Be careful pulling apart. There is two small washers on the base. Unit and mounting will come apart. NOTE THE TWO WIRE CONNECTIONS. Unsoder the wires. Now your ready to take the 914 gauge apart the same way you did the back of the Saab gauge. Remove needle and face screws. Go around the back and undo one post nut. Base will separate from the back. CHECK WIRE CONNECTIONS. Unsoder from base. Take the 914 unit over to the Saab base and match up the wire terminal. Soder in the wire and capacitor. Reassemble base with two small washers and 1st nut. Put ground spade and 2nd nut on centering the spade. Your conversion is DONE. Ready to send off for face plate silk screening. If you have some needle paint, go ahead and paint it too. (NHS charges $15 to paint needle).
If you started out with a known good gauge your costs should only be for a new black trim ring and silk screen cost. Trim rings are $45 each. Attached image(s)
| 914forme |
May 3 2018, 07:59 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Working with a company right now, on a different project. If it goes well it is an easy print on this media. And application onto the face is easy. The gauge would be no where near $850 to reproduce.
If you sourced the gauge and sent the 914 fuel gauge, easy but still have to run the numbers. But I will say most likely the final number would be devided by 8. |
| Miguel K R |
Oct 17 2020, 03:28 AM
Newbie ![]() Group: Members Posts: 20 Joined: 12-December 19 From: Portugal (Europe) Member No.: 23,732 Region Association: None |
Working with a company right now, on a different project. If it goes well it is an easy print on this media. And application onto the face is easy. The gauge would be no where near $850 to reproduce. If you sourced the gauge and sent the 914 fuel gauge, easy but still have to run the numbers. But I will say most likely the final number would be devided by 8. I am a bit confused because the 914 needle goes from R to 4/4 counterclockwise, while on the 914-6 GT replica gauge the needle works clockwise. Can you please clarify this ? I really liked your idea of silk screen printing, as until now I had only seen people printing (I guess printed on some self adhesive vinyl). At my company I have all the equipment to silk screen print (we produce plastic buckets and returnable boxes for logistics). Would you please be so kind to send me the file with the definition of the print ? My email is mritto@psaplast.com In return I am willing to silk screen a few pieces for you (it would take a few months because I am in Portugal, Europe, and to avoid hassle with Customs asking for the invoice and a proof of the payment, you would have to send the dials to my son in Philadelphia and when he comes for Christmas (or for Summer holidays) he would bring them and take them back printed, to mail to you. Miguel |
914Sixer Making 914-6 GT Style Fuel Gauge Don't Spend Big $$$$ May 2 2018, 05:10 PM
914Sixer I thought this might be a hot ticket after finding... May 3 2018, 02:20 PM
pete000 Who is doing the screen printing? May 3 2018, 04:48 PM
914Sixer Thinking NHS. I just wanted to make sure of no ou... May 3 2018, 05:36 PM
rgalla9146 :popcorn:
Mmmmm.
Need this. Great inf... Oct 17 2020, 05:59 AM
nditiz1 Mark told me the only piece you actually use from ... Oct 17 2020, 06:54 AM
Retroracer Re: fascia (and not spending big $$... Oct 17 2020, 12:46 PM
FlacaProductions @Retroracer - looks good - which sticker company ... Oct 17 2020, 01:06 PM
Retroracer
[b]@[url=http://www.914world.com/bbs2/index.php?s... Oct 17 2020, 03:47 PM
FlacaProductions Thanks - was having difficulty finding a place tha... Oct 17 2020, 04:59 PM
914forme
Thanks - was having difficulty finding a place th... Oct 17 2020, 06:02 PM
nditiz1 Does anyone know where I can buy/get a longer need... Oct 17 2020, 07:10 PM
Miguel K R I cannot imagine anyone selling a needle to suit a... Dec 10 2020, 04:16 PM
914forme Any sign shop that does vinyl wraps should be able... Oct 17 2020, 05:52 PM
Montreal914 ...So how exactly did the movement get reversed co... Dec 10 2020, 08:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd August 2026 - 01:11 PM |
