| shane |
Oct 17 2020, 08:51 AM
Member ![]() ![]() Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
| 914Sixer |
Oct 17 2020, 09:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,563 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place.
| shane |
Oct 17 2020, 09:51 AM
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place. Great idea I’m replating the originals so I’ll just do the fronts first then reinstall them and then do the rears. Thanks |
shane Removing Oct 17 2020, 08:51 AM
ndfrigi Those allen bolts holds the strut and it will chan... Oct 17 2020, 08:55 AM
shane
Those allen bolts holds the strut and it will cha... Oct 17 2020, 09:11 AM
JOEPROPER Yes, they will move. Will need to be re-aligned e... Oct 17 2020, 09:17 AM
ndfrigi Are you planning to change your insert from the st... Oct 17 2020, 09:19 AM
bdstone914 Take out one bolt at a time and replace with anoth... Oct 17 2020, 09:50 AM
bdstone914
Take out one bolt at a time and replace with anot... Oct 17 2020, 12:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 01:45 PM |
