| CG-914 |
Oct 17 2020, 02:23 PM
Member ![]() ![]() Group: Members Posts: 327 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
ALL SOLD, For sale are two things:
Pair of front 911 BOGE Struts 3 inch spacing in good condition, need to be painted. They came of an early 70s 911E. Perfect For ATE M calipers as well as Brembo Calipers. - These are a must for 5 Lug conversion. - Boge is the best choice, because you have a choice of ALL shock inserts. SOLD: A Pair of Brembo Aluminium Calipers with a set of new Hawk HPS (High Performance Street) pads. The Calpiers have the same Piston diameter as the ATE 911 S calipers, but with these advantages: - Lighter - Less flex - Cheaper - No leak issues SOLD $350 for the Brembo Calipers with Pads. These are located in OC California. Buyer is responsible for pick up or shipping cost. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| Superhawk996 |
Oct 18 2020, 09:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,042 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Those Brembo calipers are not the Porsche S calipers. They should be 3" spacing to work with early 3" 911 struts.
Agree that a photo of strut ear spacing won't hurt and would be a benefit to potential buyers having once upon a time ended up with 3.5" struts that were advertised as 3". |
CG-914 SOLD: Front 911 BOGE Struts 3" and BREMBO Calipers with Hawk Pads Oct 17 2020, 02:23 PM
bdstone914 @CG-914
S calipers require 3.5 inch bolt spacin... Oct 17 2020, 04:10 PM
Robarabian Seller: Ok, so now I'm confused. Do these bolt... Oct 18 2020, 08:29 AM
Literati914 Those are most likely Brembo's off an Alfa Rom... Oct 18 2020, 09:32 AM
Robarabian PM sent ref the calipers. Oct 18 2020, 05:00 PM
CG-914 Here are the pictures with measurements, proving, ... Oct 19 2020, 11:42 AM
AZBanks If you replace the word "Brembo" with ... Oct 19 2020, 03:45 PM
CG-914 Those are not the same thing @[url=http://www.914... Oct 19 2020, 03:50 PM
Montreal914 I don't understand why all this confusion. :c... Oct 19 2020, 08:22 PM
Mark Henry
I don't understand why all this confusion. :... Oct 29 2020, 11:46 AM
Robarabian purchased.. Oct 19 2020, 10:01 PM
CG-914
purchased..
Yes, Calipers are sold.
Struts ar... Oct 19 2020, 10:07 PM
CG-914 :bump:
REDUCED TO $425 Oct 26 2020, 10:47 AM
Alain V.
:bump:
REDUCED TO $425
sending you a PM Oct 28 2020, 09:06 PM
Franky_Four_Fingers Interested in Struts, sent you a PM. Nov 1 2020, 03:38 PM
CG-914 Sorry, all sold. Will update Post.
Interested in... Nov 2 2020, 11:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 03:59 AM |
