| AZBanks |
Jun 15 2020, 01:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals?? |
| AZBanks |
Oct 19 2020, 02:00 AM
Arizona has seriously messed up classic car registration rules. You have to have classic car insurance to get a classic car registration. I can't find an insurance company who will do classic car insurance unless every licensed driver in the family has a daily driver. The insurance companies don't take into account that my son lives on campus and this car sits in the parking garage and doesn't move except when he takes it for a short drive once a week or so. So I am stuck dealing with emissions testing. I'm pretty sure I can get it to pass, if not, I will take it back to Don Jackson. He got the 1.8 liter engine that was in the car to pass.
I just pulled the transmission back out. I took out the clutch and pressure plate but then I took a closer look before removing the fly wheel. I didn't see any oil around the bottom of the case near the fly wheel so I slid a bunch of paper towel up behind the flywheel and scrubbed it against the case really well to see how much oil was leaking back in there. I pulled the paper towel out and it was bone dry. It was a bit dusty but not a drop of oil. The RMS is not leaking. So my next thought was maybe the new front seal on the transmission didn't seal up properly so I pulled the shift fork, throw out bearing and cover tube off and the seal was dry. It's not the RMS, it's not the transmission front seal, the only other place I saw oil was from the taco plate. Maybe it is leaking a little more than I thought. I'll put the trans back in and then reseal the taco plate and hopefully that is the end of the oil leaks at least for a little while. |
AZBanks Overfilled the transmission Jun 15 2020, 01:25 PM
911GT2
I installed a replacement transmission in the 71.... Jun 15 2020, 01:29 PM
Frankvw just take out the fillplug and let the surplus com... Jun 15 2020, 01:30 PM
GregAmy I'm not sure how it's possible to overfill... Jun 15 2020, 01:44 PM
AZBanks
I'm not sure how it's possible to overfil... Jun 15 2020, 02:21 PM
GregAmy I suppose it's possible that, with only ... Jun 15 2020, 03:16 PM
Tdskip
I suppose it's possible that, with only ... Jun 15 2020, 04:29 PM
porschetub Also make sure the top vent is clear....it could b... Jun 15 2020, 04:11 PM
PlaysWithCars
Also make sure the top vent is clear....it could ... Jun 15 2020, 10:46 PM
AZBanks The trans was leaking out of the input shaft seal.... Oct 9 2020, 01:21 AM
Tdskip
The trans was leaking out of the input shaft seal... Oct 9 2020, 06:07 AM
ndfrigi
The trans was leaking out of the input shaft seal... Oct 9 2020, 09:50 AM
AZBanks Thanks for the suggestions.
It is the old seals ... Oct 9 2020, 07:25 PM
ndfrigi Are you draining the gear oil? I don’t you need ... Oct 9 2020, 07:36 PM
AZBanks Dr. Evil said not to use Swepco, He says the best ... Oct 9 2020, 07:45 PM
iankarr Try putting a screw or two into the old seal to gi... Oct 9 2020, 07:50 PM
AZBanks I bought a cheap harbor freight seal puller. It wo... Oct 9 2020, 10:51 PM
AZBanks In my "front engine 914" thread I docume... Oct 17 2020, 08:14 PM
mrholland2
In my "front engine 914" thread I docum... Oct 20 2020, 09:39 AM
AZBanks
In my "front engine 914" thread I docu... Oct 20 2020, 11:25 AM
michael7810 I had similar experience getting mine thru emissio... Oct 18 2020, 07:36 AM
bandjoey Just and FYI on insurance Haggerty never asked... Oct 19 2020, 11:37 PM
AZBanks
Just and FYI on insurance Haggerty never aske... Oct 20 2020, 02:25 AM
AZBanks
Just and FYI on insurance Haggerty never aske... Dec 7 2020, 05:47 PM
914e
Just and FYI on insurance Haggerty never ask... Dec 7 2020, 10:30 PM
AZBanks Since the exhaust is off while the trans is out, I... Oct 20 2020, 02:28 AM
AZBanks Nothing like a professional wrap job.
Oct 20 2020, 02:30 AM
AZBanks Yeah, really, this is NOTHING like a professional ... Oct 20 2020, 02:31 AM
VaccaRabite Why did you wrap it?
That wrap holds oil and greas... Oct 20 2020, 07:27 AM
AZBanks
That wrap holds oil and grea... Oct 20 2020, 01:47 PM
AZBanks I got the trans back in the car and everything els... Nov 1 2020, 01:12 AM
VaccaRabite Yeah collector car insurance wants each driver to ... Dec 8 2020, 12:16 PM
AZBanks I get their reasoning for most people but not ever... Dec 9 2020, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 12:11 AM |
