Looking for a thread, Cars not run for 10+ years |
jim_hoyland |
Oct 19 2020, 06:26 AM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I've seen the list, but never book marked it: A friend has a 914 that he hasn't started in 10 years. I' looking for the thread that go through the steps of what to do and what not to do.
jim_hoyland |
Oct 19 2020, 10:36 AM
Thanks, I was looking for a checklist I could print out for the owner. He's going to take the car in to PCH Garage, but I want to show him a list. Obvious stuff like the fuel tank are things he can do.
914sgofast2 |
Oct 19 2020, 10:45 AM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I bought a 1970 model year 914 that had been sitting in a barn since 1988. We had to replace all fuel hoses and the fuel filter; then replaced all 4 fuel injectors because they started leaking shortly after it started running. Replace thr spark plugs, but before uou indtall the new ones swiirt some ATF into each cylinder snd crank the engine over eith thr new battery you just had to install.
jim_hoyland |
Oct 19 2020, 05:26 PM
I bought a 1970 model year 914 that had been sitting in a barn since 1988. We had to replace all fuel hoses and the fuel filter; then replaced all 4 fuel injectors because they started leaking shortly after it started running. Replace thr spark plugs, but before uou indtall the new ones swiirt some ATF into each cylinder snd crank the engine over eith thr new battery you just had to install. That's good info. I'm going to make up a step by step guide for the owner. Things we take for granted, like removing and cleaning the fuel tank and related parts require detailed "how to" info. |
fiacra |
Oct 20 2020, 12:53 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 344 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
I bought a 1970 model year 914 that had been sitting in a barn since 1988. We had to replace all fuel hoses and the fuel filter; then replaced all 4 fuel injectors because they started leaking shortly after it started running. Replace thr spark plugs, but before uou indtall the new ones swiirt some ATF into each cylinder snd crank the engine over eith thr new battery you just had to install. That's good info. I'm going to make up a step by step guide for the owner. Things we take for granted, like removing and cleaning the fuel tank and related parts require detailed "how to" info. I'm bumping this to the top because if Jim is going to be kind enough to put together a list (and hopefully share it) let's see what the collective can add to help make it comprehensive and helpful. I know a lot of people would find this useful. I'll add two random thoughts: check the tires for dry rot and flat spots. Check the date code on the tires and replace even if the look good if they are over 8 years old. I know replacing the fuel lines has already been said, but adding more information about how much and what type of fuel line is needed, etc... |
Lo-Fi Version | Time is now: 7th June 2024 - 10:56 PM |
