Results from changing my tranny oil to SWEPCO 201, Comments on transmission oil. |
steuspeed |
Dec 18 2011, 07:20 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I have had my car about 6 months now. It has 105k on the clock. No record of when the last time the transmission oil was changed. First and second gear syncros are toast, but if I am real careful I can get it to slip in without grinding. Got to put it in first just before you come to a stop. I just changed the oil (Brad Penn) and thought it would be a good time to try some SWEPCO 201 in the transmission. The oil that drained out looked pretty good. Still had an amber color to it but a little on the low side. So now with the SWEPCO 3rd has a real notchy feel to it. second will zip on the teeth as I come down from third with my usual methods. First is even more finicky than before. Outside Temp is 35-45 degree range right now. Will this get better over time? Seems like I went backwards. (IMG:style_emoticons/default/sad.gif) Any comments welcome.
Lucky9146 |
Oct 22 2020, 11:33 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,621 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
You learn something new everyday. Going to get that Swepco out and replace and it as it sounds like it may improve things. This has been a helpful thread, sure glad it was resurrected after 9 years. When the timing is right I will be putting my 915 trans in and will go with what has been recommended here.
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
Steve |
Oct 22 2020, 11:47 AM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
You learn something new everyday. Going to get that Swepco out and replace and it as it sounds like it may improve things. This has been a helpful thread, sure glad it was resurrected after 9 years. When the timing is right I will be putting my 915 trans in and will go with what has been recommended here. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) I have swepco in my 915 trans now, since that is what PMS installed. I will eventually swap it out for Kendall, which can be purchased with LSD additive from Pelican. Andy from Callas Rennsport recommended Brad Penn with LSD additive, but I didn't notice any difference from the Kendall. Lots of threads on Pelican on Swepco, similar to this thread. That's how I found out about Kendall, which does seem to shift better/smoother for me and my 915 trans. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:21 AM |
