Thoro-Tec air intake, Has anyone tried this intake system |
914-300Hemi |
Oct 22 2020, 07:17 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
I found this air intake system for Weber carbs from Thoro-Tec Thoro-Ted web site
They also have other 914 related items. |
Superhawk996 |
Oct 23 2020, 06:30 AM
914 Guru Group: Members Posts: 5,898 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
"Looks" nice from an elegant visual design standpoint but I'm wondering how it flows and whether or not it accomodates velocity stacks.
It looks constricted to me forcing a 90 degree airflow change and potential for turbulence just before the venturi. However, I've seen CFD on other designs that I thought didn't look optimal and they performed well both in CFD and later on during validation testing. This is the sort of stuff that I think the company needs to provide CFD and/or dyno proof before I'd shell out $1000 for what is esentially a pretty air filter. |
SirAndy |
Oct 23 2020, 10:50 AM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
"Looks" nice from an elegant visual design standpoint but I'm wondering how it flows and whether or not it accomodates velocity stacks. @Superhawk996 Wouldn't the long runners double as velocity stacks? Seems like they should ... (IMG:style_emoticons/default/idea.gif) |
Superhawk996 |
Oct 23 2020, 11:04 AM
"Looks" nice from an elegant visual design standpoint but I'm wondering how it flows and whether or not it accomodates velocity stacks. @Superhawk996 Wouldn't the long runners double as velocity stacks? Seems like they should ... (IMG:style_emoticons/default/idea.gif) @SirAndy I think you are right they might serve to boost flow velocity initially but then that 90 degree turn without much height above the venturi would mess it up as it then decelerates flow into the tiny "plenum" over the 2 barrels of the carb. Velocity stacks might help restablish a linear flow down into the venturi but those little plenums above each carb would seem to constrict flow downward into a velocity stack for each venturi. All purely speculation on my part. At a bare minimum I'd want to see a dyno plot that shows HP is at least equal to standard IDF style filters. I really do like how clean it looks. Just not convinced it won't cost HP. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:25 PM |
