> Trailing arm bushings, Tutorial?
Porschef
post Sep 5 2020, 02:37 PM
How you doin'
There’s a pretty good chance I may be removing these on Labor(!) day, is there a recommended/preferred tutorial for this procedure? I’ve seen a YouTube video or two, but they’re not as descriptive as I’d hoped for. This’ll be my first rodeo...
I don’t know what’s happened to the search feature but it ain’t what it used to be.
Thanks in advance all.
914_teener
post Oct 23 2020, 02:01 PM
I've done these and you need to think about how it functions and how it was designed.
The replacements "bushings" orginally do not function as how the swing arm was orginally designed. My opinion since I did not design them.
Originally the rubber is vulcanized into the control arm with the metal rod through it. Sorry don't have the PET as reference. The arm acts more torsionally and as a damper for vibration. I just think this was a cheaper way of doing it. Addtionally.....check the swing arm first to make sure they aren't bent...I'm sure you probably already know this .
Over time this rubbercompound deteriorates and cracks putting the torsional load onto the mounting nut or attachment point (the slotted 17MM nut if IIRC). This will and does oval that hole out.
Now...the replacements since they are not vulcanized into the shaft act more like true bushings. When I replaced mine I realized that they are a compromise to the design.
I would suggest the hardest coumpound possible without sacraficing dampening. Since the shaft will now rotate through it's degrees of freedom which are compound by the way, I put zerk fittings around the arm and cut sprial grooves into the inside edge of the bushings.
I deemed the Elephant ones to hard in durometer for my liking. Other opinions may vary. If you can bend that outside flange I'd think those too soft and maybe an issue to align the car. IMHO.
At the time Eric at PMB just started selling them and those worked out ok. Now I think Mark at 914 Rubber may sell the very same ones.
Good luck....I did all the rear bearings since I took both control arms off and the hubs and the CV's. Well worth doing all of them and never worried about the rear suspension after that.
I wrote a thread on this....probably six years ago...scary.
Porschef   Trailing arm bushings   Sep 5 2020, 02:37 PM
mgp4591   There’s a pretty good chance I may be removing ...   Sep 5 2020, 03:09 PM
76-914   There’s a pretty good chance I may be removing ...   Sep 5 2020, 03:21 PM
bkrantz   I used a hydraulic press to remove my old bushings...   Sep 5 2020, 09:04 PM
mepstein   I used a hydraulic press to remove my old bushing...   Sep 6 2020, 07:30 AM
Porschef   Going for a rebuild; I know I have a bad bearing a...   Sep 6 2020, 06:34 AM
aharder   Ian Karr has a Youtube of removal and replacement ...   Sep 6 2020, 09:12 AM
Montreal914   Ian Karr has a Youtube of removal and replacement...   Sep 6 2020, 10:08 AM
aharder   [quote name='aharder' post='2848955' date='Sep 6 ...   Sep 6 2020, 10:22 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 6 2020, 12:51 PM
iankarr   Rear trailing arm video coming soon...waiting for ...   Sep 6 2020, 08:15 PM
Porschef   Rear trailing arm video coming soon...waiting for...   Sep 8 2020, 07:36 AM
914werke   Rear trailing arm video coming soon... Using what...   Sep 7 2020, 12:44 PM
Montreal914   I got a set of 914Rubber with the group buy not to...   Sep 7 2020, 01:33 PM
bbrock   I got a set of 914Rubber with the group buy not t...   Sep 8 2020, 07:51 AM
Porschef   I got a set of 914Rubber with the group buy not ...   Sep 8 2020, 01:57 PM
bbrock   [quote name='bbrock' post='2849427' date='Sep 8 2...   Sep 8 2020, 03:12 PM
Montreal914   [quote name='bbrock' post='2849427' date='Sep 8 2...   Sep 8 2020, 09:40 PM
bbrock   That's the crazy thing. We had the Bridger Fo...   Sep 8 2020, 10:13 PM
914werke   I got a set of 914Rubber with the group buy not t...   Oct 23 2020, 01:33 PM
914_teener   I've done these and you need to think about ho...   Oct 23 2020, 02:01 PM
Montreal914   @914werke Here's another angle on the ones I ...   Oct 23 2020, 02:01 PM
914werke   Thanks for the confirmation. Was hard to tell from...   Oct 23 2020, 02:33 PM
914_teener   Thanks for the confirmation. Hard to tell from th...   Oct 23 2020, 02:51 PM
914werke   I think Kent [b]@[url=http://www.914world.com/bb...   Oct 23 2020, 05:18 PM
76-914   I can't even remember what I had for breakfast...   Oct 23 2020, 07:34 PM
914werke   :first: gotta make some tools :smash:   Oct 23 2020, 07:39 PM
Mikey914   As you all know these cars were built inexpensivel...   Oct 24 2020, 09:28 AM
76-914   Thanks for the confirmation. Hard to tell from t...   Oct 24 2020, 12:23 PM
- Lo-Fi Version Time is now: 9th April 2026 - 03:44 PM
