> Fan belt access on a /6 once car is installed
Tdskip
post Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess...
Thanks!
Superhawk996
post Oct 22 2020, 10:24 AM
QUOTE(Tdskip @ Oct 22 2020, 11:56 AM) *
Thanks!
1st rule of mid engine cars applies -- Drop the engine. (IMG:style_emoticons/default/biggrin.gif)
Mark Henry and others have created access panels for easy access. For me that isn't an option. I just cant bring myself to cut a hole like that though I'm sure it works for fan access and alternator replacment.
Early on in my teener ownership I just learned to drop the engine. I will grant that dropping a six is not as simple as dropping the type 4. However, I still see it as the price of entry to the mid-engine cars. Pantera might the the only mid engine car that I can think of that looks remotely serviceable.
Had a work acquaintenace that owned a Ferrari 308. Same schtick. All sorts of creative ways to try to service stuff with engine in but he concedes that it was usually quicker to just drop the engine.
Mark Henry
post Oct 22 2020, 11:24 AM
that's what I do!
QUOTE(Superhawk996 @ Oct 22 2020, 12:24 PM) *
Thanks!
This makes my life so much easier.
https://www.youtube.com/watch?v=/4CaU9UQmFfk?t=58
Superhawk996
post Oct 22 2020, 03:36 PM
QUOTE(Mark Henry @ Oct 22 2020, 01:24 PM) *
@Mark Henry
Love the red fan. I've been debating whether or not I'd need to have a red fan in a 914 since you really can't see it. This might have put me over the top. Did you powder coat or paint?
It just seems right.
Plus it adds like 15 HP right (IMG:style_emoticons/default/confused24.gif)
Someday I'll be sitting by the side of the road with a tossed fan belt wishing I had just cut the damn hole. (IMG:style_emoticons/default/hissyfit.gif)
Mark Henry
post Oct 23 2020, 05:35 PM
that's what I do!
QUOTE(Superhawk996 @ Oct 22 2020, 05:36 PM) *
@Mark Henry
The fan was red when I got it in a parts lot, I knew it couldn't be seen so I ran with it. Not sure if it's powdercoat or catalyzed auto paint.
I think Motor Miester used to paint their fans red. (IMG:style_emoticons/default/laugh.gif)
Tdskip   Fan belt access on a /6 once car is installed   Oct 22 2020, 09:56 AM
Superhawk996   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 10:24 AM
Mark Henry   [quote name='Tdskip' post='2860880' date='Oct 22 ...   Oct 22 2020, 11:24 AM
Superhawk996   :D This makes my life so much easier. @Mark...   Oct 22 2020, 03:36 PM
Mark Henry   [quote name='Mark Henry' post='2860908' date='Oct...   Oct 23 2020, 05:35 PM
Steve   [quote name='Tdskip' post='2860880' date='Oct 22...   Oct 22 2020, 05:20 PM
brant   clay says its doable. I'm guessing that the fi...   Oct 22 2020, 10:27 AM
Racer   If it can be done with a stock 2.0/6, then why not...   Oct 22 2020, 11:01 AM
Steve   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 11:19 AM
rgalla9146   If you have the factory tool kit tools for your fa...   Oct 22 2020, 02:49 PM
Gint   I had no trouble doing it on a stock 2.0 6 cylinde...   Oct 22 2020, 03:04 PM
Coondog   Remove the back pad, make the cut then recover. Ca...   Oct 22 2020, 03:51 PM
ClayPerrine   I will NOT cut a hole in something called a ...   Oct 22 2020, 04:23 PM
Superhawk996   I will NOT cut a hole in something called a ...   Oct 23 2020, 03:58 PM
mlindner   I get it Clay. But remember your only one rear gla...   Oct 22 2020, 04:52 PM
Tdskip   As always great discussion and considerations.   Oct 22 2020, 05:42 PM
Mark Henry   With my twin plug dizzy it's hard to see the b...   Oct 22 2020, 05:54 PM
PanelBilly   I changed my belt in the parking lot at WCR a few ...   Oct 22 2020, 05:56 PM
rgalla9146   I have a car with an access and a car without. ...   Oct 22 2020, 06:49 PM
fixer34   I did the belt replacement with engine in the car ...   Oct 23 2020, 03:07 PM
Superhawk996   I did the belt replacement with engine in the car...   Oct 23 2020, 03:15 PM
horizontally-opposed   So if you don't want to buy a plaid factory to...   Oct 23 2020, 03:39 PM
Superhawk996   So if you don't want to buy a plaid factory t...   Oct 23 2020, 03:55 PM
dr.tim   Any leads on how to get the specialized toolsâ€...   Oct 24 2020, 05:13 PM
Superhawk996   Make one. Welder, 24mm socket, 1” angle iron....   Oct 25 2020, 06:46 AM
nditiz1   I did run into issues with the OEM style mount and...   Oct 23 2020, 04:30 PM
Superhawk996   I did run into issues with the OEM style mount an...   Oct 23 2020, 04:44 PM
nditiz1   I did take pics. I'll shoot some over to you....   Oct 23 2020, 05:19 PM
sixnotfour   Hardest belt ever to change is a 76 with air pump....   Oct 24 2020, 02:58 AM
mepstein   Someone had put a torch to a flat wrench and put s...   Oct 25 2020, 11:02 AM
Maltese Falcon   Small access plate on Sonauto #40   Oct 25 2020, 05:18 PM
GeorgeRud   I also just got a closed end wrench for the pulle...   Oct 25 2020, 05:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:39 AM
