> Fan belt access on a /6 once car is installed
Tdskip
post Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess...
Thanks!
horizontally-opposed
post Oct 23 2020, 03:39 PM
So if you don't want to buy a plaid factory tool kit remake, and don't want to fight over original tool kits with the concours mega-bucks crowd, but do want to build up a useful tool kit for your 914 six conversion...
Any leads on how to get the specialized tools—particularly for the fan belt?
Superhawk996
post Oct 23 2020, 03:55 PM
QUOTE(horizontally-opposed @ Oct 23 2020, 05:39 PM) *
Really only two tools (well maybe 3)? Stated tonque in cheek having clearly admitted I've never actually done this job in car and on a 914.
1) the fan pulley wrench
https://www.pelicanparts.com/More_Info/PELT...AiABEgK55PD_BwE
2) What ever magic low profile tool you can find to turn the fan pulley nut that fits between the nut and the bulkhead. I'm thinking ratcheting gear wrench type tool.
3) Magic breaker bars to get more leverage on the other two tools since the nut will invariably be too Fuching tight to easily loosen while you're contorted into the engine bay! I supect I'd want one long enough to fit the pulley wrench but yet land on the side engine shelf/frame on the passenger side. The other to be short enough to still move it within the engine compartment and not be hitting the engine lid when I turn it.
dr.tim
post Oct 24 2020, 05:13 PM
QUOTE(Superhawk996 @ Oct 23 2020, 03:55 PM) *
Make one. Welder, 24mm socket, 1” angle iron.
Tdskip   Fan belt access on a /6 once car is installed   Oct 22 2020, 09:56 AM
Superhawk996   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 10:24 AM
Mark Henry   [quote name='Tdskip' post='2860880' date='Oct 22 ...   Oct 22 2020, 11:24 AM
Superhawk996   :D This makes my life so much easier. @Mark...   Oct 22 2020, 03:36 PM
Mark Henry   [quote name='Mark Henry' post='2860908' date='Oct...   Oct 23 2020, 05:35 PM
Steve   [quote name='Tdskip' post='2860880' date='Oct 22...   Oct 22 2020, 05:20 PM
brant   clay says its doable. I'm guessing that the fi...   Oct 22 2020, 10:27 AM
Racer   If it can be done with a stock 2.0/6, then why not...   Oct 22 2020, 11:01 AM
Steve   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 11:19 AM
rgalla9146   If you have the factory tool kit tools for your fa...   Oct 22 2020, 02:49 PM
Gint   I had no trouble doing it on a stock 2.0 6 cylinde...   Oct 22 2020, 03:04 PM
Coondog   Remove the back pad, make the cut then recover. Ca...   Oct 22 2020, 03:51 PM
ClayPerrine   I will NOT cut a hole in something called a ...   Oct 22 2020, 04:23 PM
Superhawk996   I will NOT cut a hole in something called a ...   Oct 23 2020, 03:58 PM
mlindner   I get it Clay. But remember your only one rear gla...   Oct 22 2020, 04:52 PM
Tdskip   As always great discussion and considerations.   Oct 22 2020, 05:42 PM
Mark Henry   With my twin plug dizzy it's hard to see the b...   Oct 22 2020, 05:54 PM
PanelBilly   I changed my belt in the parking lot at WCR a few ...   Oct 22 2020, 05:56 PM
rgalla9146   I have a car with an access and a car without. ...   Oct 22 2020, 06:49 PM
fixer34   I did the belt replacement with engine in the car ...   Oct 23 2020, 03:07 PM
Superhawk996   I did the belt replacement with engine in the car...   Oct 23 2020, 03:15 PM
horizontally-opposed   So if you don't want to buy a plaid factory to...   Oct 23 2020, 03:39 PM
Superhawk996   So if you don't want to buy a plaid factory t...   Oct 23 2020, 03:55 PM
dr.tim   Any leads on how to get the specialized tools...   Oct 24 2020, 05:13 PM
Superhawk996   Make one. Welder, 24mm socket, 1” angle iron....   Oct 25 2020, 06:46 AM
nditiz1   I did run into issues with the OEM style mount and...   Oct 23 2020, 04:30 PM
Superhawk996   I did run into issues with the OEM style mount an...   Oct 23 2020, 04:44 PM
nditiz1   I did take pics. I'll shoot some over to you....   Oct 23 2020, 05:19 PM
sixnotfour   Hardest belt ever to change is a 76 with air pump....   Oct 24 2020, 02:58 AM
mepstein   Someone had put a torch to a flat wrench and put s...   Oct 25 2020, 11:02 AM
Maltese Falcon   Small access plate on Sonauto #40   Oct 25 2020, 05:18 PM
GeorgeRud   I also just got a closed end wrench for the pulle...   Oct 25 2020, 05:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:32 AM
