> Fan belt access on a /6 once car is installed
Tdskip
post Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess...
Thanks!
post Oct 25 2020, 11:02 AM
914-6 GT in waiting
Someone had put a torch to a flat wrench and put some bends in it to access the nut. Looked pretty slick. I’ll try to find a pic.
Found it
I was thinking that one easy alternative to a hatch would be a 1-1.5” hole in front of the fan pulley nut. Just large enough to stick a socket or impact gun to the nut. You would still have to work all the parts on and off through the engine bay but it’s really loosening and tightening that nut that causes issues.
Disclaimer - I’ve never fixed one on the road so no real experience.
Tdskip   Fan belt access on a /6 once car is installed   Oct 22 2020, 09:56 AM
Superhawk996   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 10:24 AM
Mark Henry   [quote name='Tdskip' post='2860880' date='Oct 22 ...   Oct 22 2020, 11:24 AM
Superhawk996   :D This makes my life so much easier. @Mark...   Oct 22 2020, 03:36 PM
Mark Henry   [quote name='Mark Henry' post='2860908' date='Oct...   Oct 23 2020, 05:35 PM
Steve   [quote name='Tdskip' post='2860880' date='Oct 22...   Oct 22 2020, 05:20 PM
brant   clay says its doable. I'm guessing that the fi...   Oct 22 2020, 10:27 AM
Racer   If it can be done with a stock 2.0/6, then why not...   Oct 22 2020, 11:01 AM
Steve   If I need to adjust (or even replace) a fan belt ...   Oct 22 2020, 11:19 AM
rgalla9146   If you have the factory tool kit tools for your fa...   Oct 22 2020, 02:49 PM
Gint   I had no trouble doing it on a stock 2.0 6 cylinde...   Oct 22 2020, 03:04 PM
Coondog   Remove the back pad, make the cut then recover. Ca...   Oct 22 2020, 03:51 PM
ClayPerrine   I will NOT cut a hole in something called a ...   Oct 22 2020, 04:23 PM
Superhawk996   I will NOT cut a hole in something called a ...   Oct 23 2020, 03:58 PM
mlindner   I get it Clay. But remember your only one rear gla...   Oct 22 2020, 04:52 PM
Tdskip   As always great discussion and considerations.   Oct 22 2020, 05:42 PM
Mark Henry   With my twin plug dizzy it's hard to see the b...   Oct 22 2020, 05:54 PM
PanelBilly   I changed my belt in the parking lot at WCR a few ...   Oct 22 2020, 05:56 PM
rgalla9146   I have a car with an access and a car without. ...   Oct 22 2020, 06:49 PM
fixer34   I did the belt replacement with engine in the car ...   Oct 23 2020, 03:07 PM
Superhawk996   I did the belt replacement with engine in the car...   Oct 23 2020, 03:15 PM
horizontally-opposed   So if you don't want to buy a plaid factory to...   Oct 23 2020, 03:39 PM
Superhawk996   So if you don't want to buy a plaid factory t...   Oct 23 2020, 03:55 PM
dr.tim   Any leads on how to get the specialized tools...   Oct 24 2020, 05:13 PM
Superhawk996   Make one. Welder, 24mm socket, 1” angle iron....   Oct 25 2020, 06:46 AM
nditiz1   I did run into issues with the OEM style mount and...   Oct 23 2020, 04:30 PM
Superhawk996   I did run into issues with the OEM style mount an...   Oct 23 2020, 04:44 PM
nditiz1   I did take pics. I'll shoot some over to you....   Oct 23 2020, 05:19 PM
sixnotfour   Hardest belt ever to change is a 76 with air pump....   Oct 24 2020, 02:58 AM
mepstein   Someone had put a torch to a flat wrench and put s...   Oct 25 2020, 11:02 AM
Maltese Falcon   Small access plate on Sonauto #40   Oct 25 2020, 05:18 PM
GeorgeRud   I also just got a closed end wrench for the pulle...   Oct 25 2020, 05:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:03 AM
