> Starter Solenoid, I have been through 4 and counting!
ctc911ctc
post Oct 25 2020, 12:47 PM
1974 2.0 - 24Kmiles
All stock
I received the car in late 2018, pulled from a garage in RI. Sat in the garage since 1986/88
The starter in the car was original. We removed near everything in the car, super cleaned and welded, put it all back together, and also bought a new starter. The new starter would not work right - clicked but no turn - so we put the original back in. Ran great.
Then the original started to fail (seemed like the copper wire from solenoid to motor had degenerated so we bought a 3rd. This one would not work so I returned it and got another. It worked great for a month and now this one clicks but the motor does not turn. Had to jump it with a screwdriver. Which though dangerous - works great!
At this point, over 2 years, I have 4 failed starters. One is 46 years old, the others are rebuilt (2) and new 1.
Which way would you go from here?
Another new OEM? (IMG:style_emoticons/default/blink.gif)
Another rebuilt???? (IMG:style_emoticons/default/barf.gif)
Put a relay in parallel with the Solenoid? (IMG:style_emoticons/default/smash.gif)
Get the super fancy Porche High Torque starter? (IMG:style_emoticons/default/first.gif)
Always park on a hill (facing downhill of course). (IMG:style_emoticons/default/lol-2.gif)
bbrock
post Oct 25 2020, 01:10 PM
QUOTE(ctc911ctc @ Oct 25 2020, 12:47 PM) *
You laugh, but I did exactly that for almost a year when I was in college with my first beater 914. (IMG:style_emoticons/default/av-943.gif)
Watching this thread as I have a box of 3 old starters and need to decide what I'm going to put in my resto. (IMG:style_emoticons/default/popcorn[1].gif)
ctc911ctc   Starter Solenoid   Oct 25 2020, 12:47 PM
bbrock   Always park on a hill (facing downhill of course)...   Oct 25 2020, 01:10 PM
dlee6204   I'm going to guess your ignition switch is act...   Oct 25 2020, 01:35 PM
ctc911ctc   I installed a bypass switch for this purpose. The ...   Oct 25 2020, 02:14 PM
Superhawk996   I installed a bypass switch for this purpose. The...   Oct 25 2020, 02:18 PM
ctc911ctc   Being a SuperHawk fan, I am going to tread very li...   Oct 25 2020, 03:41 PM
davep   I have measured the voltage against the engine (g...   Oct 26 2020, 08:35 AM
michael7810   I drove my car for almost 10 years on a rebuilt st...   Oct 25 2020, 01:37 PM
Superhawk996   :agree: with the two posts above. Your chance o...   Oct 25 2020, 01:58 PM
AZBanks   I would suggest giving Mark Henry's fix a try....   Oct 25 2020, 02:06 PM
Superhawk996   I would suggest giving Mark Henry's fix a try...   Oct 25 2020, 02:16 PM
porschetub   I would suggest giving Mark Henry's fix a try...   Oct 25 2020, 04:54 PM
Superhawk996   [quote name='AZBanks' post='2861707' date='Oct 26...   Oct 25 2020, 05:37 PM
GeorgeRud   Clean and verify the grounds, then attach a jumper...   Oct 25 2020, 04:15 PM
Superhawk996   OK. Like the troubleshooting aspect of the bypass...   Oct 25 2020, 04:52 PM
fixer34   Now that we beat the electrical issues to death, w...   Oct 25 2020, 05:27 PM
JOEPROPER   FWIW, I replaced my old starter (high amp draw) wi...   Oct 26 2020, 09:09 AM
ctc911ctc   *******UPDATE******* The original Starter has a t...   Nov 19 2020, 06:34 PM
Superhawk996   :first: for perseverance. Hard to believe you...   Nov 19 2020, 07:30 PM
Cairo94507   Great job working the problem and resolving it. ...   Nov 19 2020, 07:33 PM
ctc911ctc   ********************* ****LAST UPDATE****** ******...   Nov 22 2020, 12:30 PM
- Lo-Fi Version Time is now: 19th September 2026 - 01:28 AM
