| ctc911ctc |
Oct 25 2020, 12:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,378 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1974 2.0 - 24Kmiles
All stock I received the car in late 2018, pulled from a garage in RI. Sat in the garage since 1986/88 The starter in the car was original. We removed near everything in the car, super cleaned and welded, put it all back together, and also bought a new starter. The new starter would not work right - clicked but no turn - so we put the original back in. Ran great. Then the original started to fail (seemed like the copper wire from solenoid to motor had degenerated so we bought a 3rd. This one would not work so I returned it and got another. It worked great for a month and now this one clicks but the motor does not turn. Had to jump it with a screwdriver. Which though dangerous - works great! At this point, over 2 years, I have 4 failed starters. One is 46 years old, the others are rebuilt (2) and new 1. Which way would you go from here? Another new OEM? (IMG:style_emoticons/default/blink.gif) Another rebuilt???? (IMG:style_emoticons/default/barf.gif) Put a relay in parallel with the Solenoid? (IMG:style_emoticons/default/smash.gif) Get the super fancy Porche High Torque starter? (IMG:style_emoticons/default/first.gif) Always park on a hill (facing downhill of course). (IMG:style_emoticons/default/lol-2.gif) |
| dlee6204 |
Oct 25 2020, 01:35 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm going to guess your ignition switch is actually the problem and not the starter. I suggest replacing your ignition switch with OEM from Porsche (~$40) before going to the additional relay route.
I've had good experience getting rebuilt starters from my local FLAPS. |
| ctc911ctc |
Oct 25 2020, 02:14 PM
I installed a bypass switch for this purpose. The ignition switch is working correctly.
The switch and the bypass switch both click the solenoid but do not engage the starter........almost as if the cross-bar in the solenoid is not touching the terminals. I'm going to guess your ignition switch is actually the problem and not the starter. I suggest replacing your ignition switch with OEM from Porsche (~$40) before going to the additional relay route. I've had good experience getting rebuilt starters from my local FLAPS. |
ctc911ctc Starter Solenoid Oct 25 2020, 12:47 PM
bbrock
Always park on a hill (facing downhill of course)... Oct 25 2020, 01:10 PM
Superhawk996
I installed a bypass switch for this purpose. The... Oct 25 2020, 02:18 PM
ctc911ctc Being a SuperHawk fan, I am going to tread very li... Oct 25 2020, 03:41 PM
davep
I have measured the voltage against the engine (g... Oct 26 2020, 08:35 AM
michael7810 I drove my car for almost 10 years on a rebuilt st... Oct 25 2020, 01:37 PM
Superhawk996 :agree: with the two posts above.
Your chance o... Oct 25 2020, 01:58 PM
AZBanks I would suggest giving Mark Henry's fix a try.... Oct 25 2020, 02:06 PM
Superhawk996
I would suggest giving Mark Henry's fix a try... Oct 25 2020, 02:16 PM
porschetub
I would suggest giving Mark Henry's fix a try... Oct 25 2020, 04:54 PM
Superhawk996
[quote name='AZBanks' post='2861707' date='Oct 26... Oct 25 2020, 05:37 PM
GeorgeRud Clean and verify the grounds, then attach a jumper... Oct 25 2020, 04:15 PM
Superhawk996 OK. Like the troubleshooting aspect of the bypass... Oct 25 2020, 04:52 PM
fixer34 Now that we beat the electrical issues to death, w... Oct 25 2020, 05:27 PM
JOEPROPER FWIW, I replaced my old starter (high amp draw) wi... Oct 26 2020, 09:09 AM
ctc911ctc *******UPDATE*******
The original Starter has a t... Nov 19 2020, 06:34 PM
Superhawk996 :first: for perseverance.
Hard to believe you... Nov 19 2020, 07:30 PM
Cairo94507 Great job working the problem and resolving it. ... Nov 19 2020, 07:33 PM
ctc911ctc *********************
****LAST UPDATE******
******... Nov 22 2020, 12:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 01:28 AM |
