> Starter Solenoid, I have been through 4 and counting!
ctc911ctc
post Oct 25 2020, 12:47 PM
1974 2.0 - 24Kmiles
All stock
I received the car in late 2018, pulled from a garage in RI. Sat in the garage since 1986/88
The starter in the car was original. We removed near everything in the car, super cleaned and welded, put it all back together, and also bought a new starter. The new starter would not work right - clicked but no turn - so we put the original back in. Ran great.
Then the original started to fail (seemed like the copper wire from solenoid to motor had degenerated so we bought a 3rd. This one would not work so I returned it and got another. It worked great for a month and now this one clicks but the motor does not turn. Had to jump it with a screwdriver. Which though dangerous - works great!
At this point, over 2 years, I have 4 failed starters. One is 46 years old, the others are rebuilt (2) and new 1.
Which way would you go from here?
Another new OEM? (IMG:style_emoticons/default/blink.gif)
Another rebuilt???? (IMG:style_emoticons/default/barf.gif)
Put a relay in parallel with the Solenoid? (IMG:style_emoticons/default/smash.gif)
Get the super fancy Porche High Torque starter? (IMG:style_emoticons/default/first.gif)
Always park on a hill (facing downhill of course). (IMG:style_emoticons/default/lol-2.gif)
AZBanks
post Oct 25 2020, 02:06 PM
I would suggest giving Mark Henry's fix a try.
http://www.914world.com/bbs2/index.php?sho...amp;mode=linear
Superhawk996
post Oct 25 2020, 02:16 PM
QUOTE(AZBanks @ Oct 25 2020, 04:06 PM) *
Mark's fix is great and has an intended purpose. It will not address bad ground connection or a flaky swith.
I'm going to pull quote from Mark's fix:
"Of course as with any electrical trouble shooting the first order of business is always clean all of your grounds and make sure the chassis to transmission ground strap is in place and in good condition."
No offense to AZBanks but this isn't a guessing game. Trouble shooting electrical issues requires a methodical approach before adding more variables and more wiring.
ctc911ctc   Starter Solenoid   Oct 25 2020, 12:47 PM
bbrock   Always park on a hill (facing downhill of course)...   Oct 25 2020, 01:10 PM
dlee6204   I'm going to guess your ignition switch is act...   Oct 25 2020, 01:35 PM
ctc911ctc   I installed a bypass switch for this purpose. The ...   Oct 25 2020, 02:14 PM
Superhawk996   I installed a bypass switch for this purpose. The...   Oct 25 2020, 02:18 PM
ctc911ctc   Being a SuperHawk fan, I am going to tread very li...   Oct 25 2020, 03:41 PM
davep   I have measured the voltage against the engine (g...   Oct 26 2020, 08:35 AM
michael7810   I drove my car for almost 10 years on a rebuilt st...   Oct 25 2020, 01:37 PM
Superhawk996   :agree: with the two posts above. Your chance o...   Oct 25 2020, 01:58 PM
AZBanks   I would suggest giving Mark Henry's fix a try....   Oct 25 2020, 02:06 PM
Superhawk996   I would suggest giving Mark Henry's fix a try...   Oct 25 2020, 02:16 PM
porschetub   I would suggest giving Mark Henry's fix a try...   Oct 25 2020, 04:54 PM
Superhawk996   [quote name='AZBanks' post='2861707' date='Oct 26...   Oct 25 2020, 05:37 PM
GeorgeRud   Clean and verify the grounds, then attach a jumper...   Oct 25 2020, 04:15 PM
Superhawk996   OK. Like the troubleshooting aspect of the bypass...   Oct 25 2020, 04:52 PM
fixer34   Now that we beat the electrical issues to death, w...   Oct 25 2020, 05:27 PM
JOEPROPER   FWIW, I replaced my old starter (high amp draw) wi...   Oct 26 2020, 09:09 AM
ctc911ctc   *******UPDATE******* The original Starter has a t...   Nov 19 2020, 06:34 PM
Superhawk996   :first: for perseverance. Hard to believe you...   Nov 19 2020, 07:30 PM
Cairo94507   Great job working the problem and resolving it. ...   Nov 19 2020, 07:33 PM
ctc911ctc   ********************* ****LAST UPDATE****** ******...   Nov 22 2020, 12:30 PM
- Lo-Fi Version Time is now: 19th September 2026 - 01:29 AM
