| ctc911ctc |
Oct 25 2020, 12:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,378 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1974 2.0 - 24Kmiles
All stock I received the car in late 2018, pulled from a garage in RI. Sat in the garage since 1986/88 The starter in the car was original. We removed near everything in the car, super cleaned and welded, put it all back together, and also bought a new starter. The new starter would not work right - clicked but no turn - so we put the original back in. Ran great. Then the original started to fail (seemed like the copper wire from solenoid to motor had degenerated so we bought a 3rd. This one would not work so I returned it and got another. It worked great for a month and now this one clicks but the motor does not turn. Had to jump it with a screwdriver. Which though dangerous - works great! At this point, over 2 years, I have 4 failed starters. One is 46 years old, the others are rebuilt (2) and new 1. Which way would you go from here? Another new OEM? (IMG:style_emoticons/default/blink.gif) Another rebuilt???? (IMG:style_emoticons/default/barf.gif) Put a relay in parallel with the Solenoid? (IMG:style_emoticons/default/smash.gif) Get the super fancy Porche High Torque starter? (IMG:style_emoticons/default/first.gif) Always park on a hill (facing downhill of course). (IMG:style_emoticons/default/lol-2.gif) |
| GeorgeRud |
Oct 25 2020, 04:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Clean and verify the grounds, then attach a jumper switch from the starter terminal to the solenoid. If it works well, the issue is in your wiring, not the starter in my opinion. Using a relay to take the load off the yellow wire is a good idea with 40+ year old wiring.
ctc911ctc Starter Solenoid Oct 25 2020, 12:47 PM
bbrock
Always park on a hill (facing downhill of course)... Oct 25 2020, 01:10 PM
dlee6204 I'm going to guess your ignition switch is act... Oct 25 2020, 01:35 PM
ctc911ctc I installed a bypass switch for this purpose. The ... Oct 25 2020, 02:14 PM
Superhawk996
I installed a bypass switch for this purpose. The... Oct 25 2020, 02:18 PM
ctc911ctc Being a SuperHawk fan, I am going to tread very li... Oct 25 2020, 03:41 PM
davep
I have measured the voltage against the engine (g... Oct 26 2020, 08:35 AM
michael7810 I drove my car for almost 10 years on a rebuilt st... Oct 25 2020, 01:37 PM
Superhawk996 :agree: with the two posts above.
Your chance o... Oct 25 2020, 01:58 PM
AZBanks I would suggest giving Mark Henry's fix a try.... Oct 25 2020, 02:06 PM
Superhawk996
I would suggest giving Mark Henry's fix a try... Oct 25 2020, 02:16 PM
porschetub
I would suggest giving Mark Henry's fix a try... Oct 25 2020, 04:54 PM
Superhawk996
[quote name='AZBanks' post='2861707' date='Oct 26... Oct 25 2020, 05:37 PM
Superhawk996 OK. Like the troubleshooting aspect of the bypass... Oct 25 2020, 04:52 PM
fixer34 Now that we beat the electrical issues to death, w... Oct 25 2020, 05:27 PM
JOEPROPER FWIW, I replaced my old starter (high amp draw) wi... Oct 26 2020, 09:09 AM
ctc911ctc *******UPDATE*******
The original Starter has a t... Nov 19 2020, 06:34 PM
Superhawk996 :first: for perseverance.
Hard to believe you... Nov 19 2020, 07:30 PM
Cairo94507 Great job working the problem and resolving it. ... Nov 19 2020, 07:33 PM
ctc911ctc *********************
****LAST UPDATE******
******... Nov 22 2020, 12:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 01:29 AM |
