02 bung into SSI exchangers?, Which pipe is best. Does it matter? |
VaccaRabite |
Oct 27 2020, 07:15 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'm doing some remote tuning through PMB for my injected 2056. The tune is close and I've been driving it but there are improvements that could be made now that I have had about a year and change since my last tuning session.
Eric suggested I move my O2 bung from the muffler (where I knew the location was not ideal but it got to sample all 4 cylinders) to one of the exchanger pipes (much better/hotter location, but only get to sample one cylinder.) Tapping into the Cylinder 1/2 bank would be easiest, and I was thinking of going into Cyl 1 since the pipe is shorter and maybe a little hotter. So now the question is what cylinder is the one I want to TIG weld the bung into. I don't track EGT so I don't really know if one pipe is hotter then another. And I want to eventually get heat back in my car so I can't go to headers which would allow me to sample all the cylinders before the muffler. Thanks! Zach @Eric_Shea |
Mark Henry |
Oct 27 2020, 10:05 AM
Don't put it in the muffler it's not hot enough for the lambda. Agreed. As I said I knew going in it was not an ideal location, but a compromise to get all 4. Not all of my ideas are great. Just ask my ex-wife. ;-) I'd put it in #2 as it's usually the most nominal operating P&C. A better idea is to weld in a chunk of 1-1/4" to 1-1/2" tube between #1 and #2 pipe, about halfway between the muffler flange and the start of the "exchanger" outer shell. Weld your bung to the top of this cross pipe. You don't have to cut the SSI pipes to match, just drill say a 1/2" hole into each of the SSI pipes. That's in interesting idea. Would enough gas make that hard 90 bend to give an accurate reading though? You want the sensor in the main gas flow as much as possible. Zach IMO it won't matter as there will be a flurry of crossflow. Make the drilled hole a bit bigger if you like. I'd use square tube, easier to weld the bung to a flat surface. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:26 AM |
