Any racers have FuelSafe? What size for sprint?, Racing fuel cells |
Stark 01 |
Oct 28 2020, 07:32 AM
Racing newbie Group: Members Posts: 43 Joined: 26-May 14 From: Concord, NC Member No.: 17,404 Region Association: South East States |
Hi everyone, I’m getting my 914 back into racing shape. The ATL fuel cell is old and was installed by PO for endurance racing, 22 gallons.
I have replaced everything downstream of the Holley pump, and now thinking of a smaller tank for sprints. (Can’t see myself doing endurance racing, although I would love to). The Fuel Safe cells are more affordable than ATL, and carry the FIA cert. They can be ordered with the Holley pickup mats, which also eliminates the need for a 100 micron filter before the pump. Does anyone here have anything negative to say about them from personal experience? What size tank should I get for my 914-4 built engine (2.0)? I’m thinking 8 gallon? |
brant |
Oct 28 2020, 10:25 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the rule was always 10 gallon for 4 cylinder
and 15 gallon for 6 cylinder the only bad thing about an FIA certification is that they expire once you are running in a group that notes the date on your FIA certified part... they will make you replace. I think FIA seat belts are 2 or 3 years I kinda remember that fuel cells might be 3 or 5 years so replacing it every 5 years would suck! there is no harm in running a fuel cell less than full there is minimal weight given up on an empty cell and it allows you to add fuel when you do eventually participate in an enduro without changing out th cell so the common sense answer is run a bigger cell with less fuel in it I add 4 gallons to my cell every single sprint race but still have the capacity of 15 gallons for longer events brant |
Stark 01 |
Oct 28 2020, 11:13 AM
the rule was always 10 gallon for 4 cylinder and 15 gallon for 6 cylinder the only bad thing about an FIA certification is that they expire once you are running in a group that notes the date on your FIA certified part... they will make you replace. I think FIA seat belts are 2 or 3 years I kinda remember that fuel cells might be 3 or 5 years so replacing it every 5 years would suck! there is no harm in running a fuel cell less than full there is minimal weight given up on an empty cell and it allows you to add fuel when you do eventually participate in an enduro without changing out th cell so the common sense answer is run a bigger cell with less fuel in it I add 4 gallons to my cell every single sprint race but still have the capacity of 15 gallons for longer events brant Thank you for taking the time. I was SCCA and it was 5 years and can be extended with an “inspection”. Eventually I want to move to historic, so I will have to find the rule book for that sanctioning body, but most likely it is 5 years for everyone. I have no choice, the stock tank is long gone, and the current one is a couple years past 5 and I am assuming so is the foam inside. |
Lo-Fi Version | Time is now: 31st May 2024 - 08:18 PM |
