02 bung into SSI exchangers?, Which pipe is best. Does it matter? |
VaccaRabite |
Oct 27 2020, 07:15 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'm doing some remote tuning through PMB for my injected 2056. The tune is close and I've been driving it but there are improvements that could be made now that I have had about a year and change since my last tuning session.
Eric suggested I move my O2 bung from the muffler (where I knew the location was not ideal but it got to sample all 4 cylinders) to one of the exchanger pipes (much better/hotter location, but only get to sample one cylinder.) Tapping into the Cylinder 1/2 bank would be easiest, and I was thinking of going into Cyl 1 since the pipe is shorter and maybe a little hotter. So now the question is what cylinder is the one I want to TIG weld the bung into. I don't track EGT so I don't really know if one pipe is hotter then another. And I want to eventually get heat back in my car so I can't go to headers which would allow me to sample all the cylinders before the muffler. Thanks! Zach @Eric_Shea |
mb911 |
Oct 27 2020, 10:18 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Tuning with the muffler that will be used every day is ideal. Its funny there was another thread recently about how all of mu mufflers should come with o2 bungs in them.. I felt it unnecessary as it is not an accurate way to measure.. It really should be in the heat exchangers.. The alternative would be in the inlet of the muffler however that would impede flow without doubt.
Frank S |
Oct 29 2020, 05:39 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
QUOTE I felt it unnecessary as it is not an accurate way to measure.. It really should be in the heat exchangers.. The alternative would be in the inlet of the muffler however that would impede flow without doubt. Why? I would agree to the statement for a Narrowband Lambda Sensor as they are not temperature controlled. Is there really somebody still using Narrowbands? From my data there is almost no difference between the sensor location at the inlet of the muffler to the center where it is much cooler. Also the Widebandcontroller is indicating a good operation temp. range. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:27 AM |
