Fuel Injection Options and Advice |
bkrantz |
Nov 2 2020, 09:15 PM
914 Guru Group: Members Posts: 7,802 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Decision time soon (preferably only once). Later this month I will pick up my refurbished case, crank, and heads from Competition Engineering in Phoenix. I want to build this up to 2056 and use fuel injection.
So, do I keep the stock D-jet that was on the car? I have no idea if it works. And I expect that I will spend time and money tracking down rebuilt/replacement components. Plus modify the system for the increased displacement. Or do I go aftermarket, spend more time and money, but hope for better results? And maybe some sexy twin intakes? |
Gint |
Nov 3 2020, 01:52 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I’m planning aftermarket FI my 2056. And I thought I wanted ITBs, but I don’t want to have to sync anything. That's one of my reasons to convert from carbs to FI.
So here’s a question... Is there any reason to think the stock djet runners, plenum, throttle body won’t flow enough air for a 2056? Discuss - I’m riding down the highway through Planet Utah. |
JamesM |
Nov 3 2020, 02:45 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
So here’s a question... Is there any reason to think the stock djet runners, plenum, throttle body won’t flow enough air for a 2056? I think you would need a pretty extreme 2056 before it becomes an issue to consider. I dont recall the exact figures but i did the math on it before and I think it doesn't become an issue until you start getting above ~140HP at which point you also need to be thinking about exhaust (headers) as well. Mine is a bit of a screamer (spins to 7k) and im running it through a modified 1.8 l-jet Plenum with 50mm Vanagon TB. I suspect where you are at the stock 2.0 plenum and runners would be preferred from a drivability standpoint as it gives a better vacuum signal, and in theory probably better midrange torque. |
Mark Henry |
Nov 4 2020, 09:59 AM
So here’s a question... Is there any reason to think the stock djet runners, plenum, throttle body won’t flow enough air for a 2056? I think you would need a pretty extreme 2056 before it becomes an issue to consider. I dont recall the exact figures but i did the math on it before and I think it doesn't become an issue until you start getting above ~140HP at which point you also need to be thinking about exhaust (headers) as well. Mine is a bit of a screamer (spins to 7k) and im running it through a modified 1.8 l-jet Plenum with 50mm Vanagon TB. I suspect where you are at the stock 2.0 plenum and runners would be preferred from a drivability standpoint as it gives a better vacuum signal, and in theory probably better midrange torque. (IMG:style_emoticons/default/smile.gif) With Djet intake and SSI's there's no way in hell you can get 140hp, at least not without fudging the dyno numbers, even 130 would be a stretch. That said the stock d-jet intake and SSI's will work fine for a 2056. Spins to 7K? Is this a full race engine? What are you doing about valve float? What cam? |
Lo-Fi Version | Time is now: 8th June 2024 - 07:35 AM |
