rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,309 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Drove around for 30 minutes in 80+ degree weather. All arterial roads, so several stop lights, etc. No problems until I was almost home. Car stalled when I stopped at a light. RPMs just dropped to zero. Was able to start it again with a little difficulty and had to keep my foot on the gas to keep it from stalling out again. Power seemed ok though the rest of the way home (I think). It stalled once again at a stop light a couple of blocks from home and then again when I pulled in the driveway. I let it sit for 30 seconds, started it again and it idled just fine. Rock solid at 1000 RPMs. Pulled it into the garage where it sits now.
Prior to today the car has been running and idling perfectly since I went through the FI parts last year, which included installing a 123 distributor, new CHT sensor, a newly rebuilt mps (calibrated for correct afr on my engine), new vacuum hoses, NOS throttle body, rebuilt injectors, new fuel pump, valve adjustment and timing. I haven’t checked the AFR since last year, not sure why it would change though. It’s a ‘75 so the fuel pump is in the front, so I can rule out vapor lock I think. Anyone have ideas as to why it would be stalling? |
yellowporky |
Member ![]() ![]() Group: Members Posts: 432 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California ![]() |
Did you ever replace the board on your TPS? 914 rubber sells them
rjames |
Did you ever replace the board on your TPS? 914 rubber sells them No, and not discounting it, but I'm stuck on how it would explain the engine stalling since the car will still run with the TPS unplugged. I did clean the board last summer even though the contacts looked good. It's been calibrated. |
Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
Did you ever replace the board on your TPS? 914 rubber sells them No, and not discounting it, but I'm stuck on how it would explain the engine stalling since the car will still run with the TPS unplugged. I did clean the board last summer even though the contacts looked good. It's been calibrated. Another WAG, but if your TPS is worn and intermittently telling the ECU you're at idle, I can see how you can go way rich or lean sporadically (depending on ecu and MPS settings) especially as engine compartment temps change. Do you have a variable resistor between the cht and ecu? I find that adds an extra knob to dial everything in. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:51 PM |
