| blabla914 |
Nov 27 2020, 07:49 PM
I like primer ![]() ![]() Group: Members Posts: 330 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None
So I’m wired up
Blue ground Red ignition hot Black to white MSD I’ve got the green LED at Z1 on the flywheel 1 TDC I re-installed plug leads with #1 aligned with where the rotor points with the green LED on. I can see 12VDC on the 123 dashboard while cranking. Just spent 2 hours double checking verifying etc. no change. I know lots of people are running this with MSD, Ben being one of them. What have I missed? Attached is a pic of my wiring. Yes I know my coil wire is a tad short. Attached thumbnail(s) |
| blabla914 |
Nov 28 2020, 09:07 AM
Thanks for posting those Mark. The car just ran on Tuesday prior to swapping the distributor. Did the check grounding the white wire. Spark is solid. Hmmmm....
blabla914 123 ignition with MSD Nov 27 2020, 07:49 PM
blabla914 Some stuff I tried:
I verified 0 ohms from my blue... Nov 27 2020, 08:19 PM
blabla914 I just tried running a jumper straight from the pl... Nov 27 2020, 08:34 PM
Mark Henry C&P from the bird post #8 of this thread by me... Nov 27 2020, 09:34 PM
blabla914 Thanks Mark I read that thread on the bird board b... Nov 27 2020, 09:41 PM
Mark Henry Trigger your MSD box by jumping the purple mag tri... Nov 27 2020, 09:47 PM
mb911 Are you sure your on z1? My guess is your just a t... Nov 28 2020, 07:51 AM
mb911
Thanks for posting those Mark. The car just ran o... Nov 28 2020, 09:37 AM
blabla914 Swapped the blue coil with 3 ohm primary resistanc... Nov 28 2020, 09:46 AM
mb911
Swapped the blue coil with 3 ohm primary resistan... Nov 28 2020, 09:51 AM
sixnotfour prob. on #4 not #1 Z1 Nov 28 2020, 10:01 AM
mb911
That could be if he didn... Nov 28 2020, 10:04 AM
blabla914
When I read this I though... Nov 28 2020, 10:27 AM
mlindner And best to have it marked on the flywheel for the... Nov 28 2020, 10:04 AM
mb911
And best to have it marked on the flywheel for th... Nov 28 2020, 10:05 AM
blabla914 IDK man.....looks like I’m right on Z1.
Has a... Nov 28 2020, 10:08 AM
mb911 Still betting on a tooth off Nov 28 2020, 10:11 AM
sixnotfour If that is a 2.4 engine , that is not Z1 Nov 28 2020, 10:17 AM
mb911
Oh go... Nov 28 2020, 10:18 AM
blabla914
Oh g... Nov 28 2020, 10:28 AM
sixnotfour
[quote name='mb911' post='2870186' date='Nov 28 2... Nov 28 2020, 10:39 AM
blabla914
[quote name='mb911' post='2870186' date='Nov 28 ... Nov 28 2020, 08:12 PM
blabla914 Ben called it. Off a tooth. I didn’t appreciate ... Nov 28 2020, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 04:22 AM |
