> 123 ignition with MSD, It tries to catch, but no start
blabla914
post Nov 27 2020, 07:49 PM
I like primer
So I’m wired up
Blue ground
Red ignition hot
Black to white MSD
I’ve got the green LED at Z1 on the flywheel 1 TDC
I re-installed plug leads with #1 aligned with where the rotor points with the green LED on.
I can see 12VDC on the 123 dashboard while cranking.
Just spent 2 hours double checking verifying etc.
no change.
I know lots of people are running this with MSD, Ben being one of them.
What have I missed?
Attached is a pic of my wiring. Yes I know my coil wire is a tad short.
blabla914
post Nov 28 2020, 09:07 AM
I like primer
Thanks for posting those Mark. The car just ran on Tuesday prior to swapping the distributor. Did the check grounding the white wire. Spark is solid. Hmmmm....
mb911
post Nov 28 2020, 09:37 AM
QUOTE(blabla914 @ Nov 28 2020, 07:07 AM) *
Its gotta be off a tooth.. I had to rotate the dizzy to get mine to fire up. There is a wide range with the LED. Lit.
blabla914   123 ignition with MSD   Nov 27 2020, 07:49 PM
blabla914   Some stuff I tried: I verified 0 ohms from my blue...   Nov 27 2020, 08:19 PM
blabla914   I just tried running a jumper straight from the pl...   Nov 27 2020, 08:34 PM
Mark Henry   C&P from the bird post #8 of this thread by me...   Nov 27 2020, 09:34 PM
blabla914   Thanks Mark I read that thread on the bird board b...   Nov 27 2020, 09:41 PM
Mark Henry   Trigger your MSD box by jumping the purple mag tri...   Nov 27 2020, 09:47 PM
mb911   Are you sure your on z1? My guess is your just a t...   Nov 28 2020, 07:51 AM
blabla914   Thanks for posting those Mark. The car just ran on...   Nov 28 2020, 09:07 AM
mb911   Thanks for posting those Mark. The car just ran o...   Nov 28 2020, 09:37 AM
blabla914   Swapped the blue coil with 3 ohm primary resistanc...   Nov 28 2020, 09:46 AM
mb911   Swapped the blue coil with 3 ohm primary resistan...   Nov 28 2020, 09:51 AM
sixnotfour   prob. on #4 not #1 Z1   Nov 28 2020, 10:01 AM
mb911   prob. on #4 not #1 Z1 That could be if he didn...   Nov 28 2020, 10:04 AM
blabla914   prob. on #4 not #1 Z1 When I read this I though...   Nov 28 2020, 10:27 AM
mlindner   And best to have it marked on the flywheel for the...   Nov 28 2020, 10:04 AM
mb911   And best to have it marked on the flywheel for th...   Nov 28 2020, 10:05 AM
blabla914   IDK man.....looks like I’m right on Z1. Has a...   Nov 28 2020, 10:08 AM
mb911   Still betting on a tooth off   Nov 28 2020, 10:11 AM
sixnotfour   If that is a 2.4 engine , that is not Z1   Nov 28 2020, 10:17 AM
mb911   If that is a 2.4 engine , that is not Z1 Oh go...   Nov 28 2020, 10:18 AM
blabla914   If that is a 2.4 engine , that is not Z1 Oh g...   Nov 28 2020, 10:28 AM
sixnotfour   [quote name='mb911' post='2870186' date='Nov 28 2...   Nov 28 2020, 10:39 AM
blabla914   [quote name='mb911' post='2870186' date='Nov 28 ...   Nov 28 2020, 08:12 PM
blabla914   Ben called it. Off a tooth. I didn’t appreciate ...   Nov 28 2020, 08:02 PM
- Lo-Fi Version Time is now: 1st May 2026 - 04:23 AM
