| blabla914 |
Nov 27 2020, 07:49 PM
I like primer ![]() ![]() Group: Members Posts: 330 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None
So I’m wired up
Blue ground Red ignition hot Black to white MSD I’ve got the green LED at Z1 on the flywheel 1 TDC I re-installed plug leads with #1 aligned with where the rotor points with the green LED on. I can see 12VDC on the 123 dashboard while cranking. Just spent 2 hours double checking verifying etc. no change. I know lots of people are running this with MSD, Ben being one of them. What have I missed? Attached is a pic of my wiring. Yes I know my coil wire is a tad short. Attached thumbnail(s) |
| blabla914 |
Nov 28 2020, 09:46 AM
Swapped the blue coil with 3 ohm primary resistance from the blaster coil with 1 ohm resistance. No difference
Also checked that the distributor body has zero ohms to ground. Ben I think you are right. My timing must be off. Going to redo that again later. |
blabla914 123 ignition with MSD Nov 27 2020, 07:49 PM
blabla914 Some stuff I tried:
I verified 0 ohms from my blue... Nov 27 2020, 08:19 PM
blabla914 I just tried running a jumper straight from the pl... Nov 27 2020, 08:34 PM
Mark Henry C&P from the bird post #8 of this thread by me... Nov 27 2020, 09:34 PM
blabla914 Thanks Mark I read that thread on the bird board b... Nov 27 2020, 09:41 PM
Mark Henry Trigger your MSD box by jumping the purple mag tri... Nov 27 2020, 09:47 PM
mb911 Are you sure your on z1? My guess is your just a t... Nov 28 2020, 07:51 AM
blabla914 Thanks for posting those Mark. The car just ran on... Nov 28 2020, 09:07 AM
mb911
Thanks for posting those Mark. The car just ran o... Nov 28 2020, 09:37 AM
mb911
Swapped the blue coil with 3 ohm primary resistan... Nov 28 2020, 09:51 AM
sixnotfour prob. on #4 not #1 Z1 Nov 28 2020, 10:01 AM
mb911
That could be if he didn... Nov 28 2020, 10:04 AM
blabla914
When I read this I though... Nov 28 2020, 10:27 AM
mlindner And best to have it marked on the flywheel for the... Nov 28 2020, 10:04 AM
mb911
And best to have it marked on the flywheel for th... Nov 28 2020, 10:05 AM
blabla914 IDK man.....looks like I’m right on Z1.
Has a... Nov 28 2020, 10:08 AM
mb911 Still betting on a tooth off Nov 28 2020, 10:11 AM
sixnotfour If that is a 2.4 engine , that is not Z1 Nov 28 2020, 10:17 AM
mb911
Oh go... Nov 28 2020, 10:18 AM
blabla914
Oh g... Nov 28 2020, 10:28 AM
sixnotfour
[quote name='mb911' post='2870186' date='Nov 28 2... Nov 28 2020, 10:39 AM
blabla914
[quote name='mb911' post='2870186' date='Nov 28 ... Nov 28 2020, 08:12 PM
blabla914 Ben called it. Off a tooth. I didn’t appreciate ... Nov 28 2020, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 04:23 AM |
