| dumbjim |
Nov 28 2020, 09:18 PM
Newbie ![]() Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
I decided to tune and sync my weber 40 idfs today for the first time. Everything went really smooth after reading about and watching video on the subject. First thing I did was check for vacuum leaks before going any further. After disconnecting the linkage and making all the adjustments, things seem to be running pretty smooth with the exception of the barrel for cylinder two will cough and burp. All four barrels are drawing 6 on my snail, with the engine warmed up. Any ideas what would cause this and possible corrections? Thanks in advance, this site has been extremely helpful to me in the past.
| 914Toy |
Nov 28 2020, 11:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
I decided to tune and sync my weber 40 idfs today for the first time. Everything went really smooth after reading about and watching video on the subject. First thing I did was check for vacuum leaks before going any further. After disconnecting the linkage and making all the adjustments, things seem to be running pretty smooth with the exception of the barrel for cylinder two will cough and burp. All four barrels are drawing 6 on my snail, with the engine warmed up. Any ideas what would cause this and possible corrections? Thanks in advance, this site has been extremely helpful to me in the past. ‘Spitting or coughing from the carb intake suggests it is too lean. Try opening up your idle mixture screw (turn counter clockwise}, 1/4 turn at a time. |
dumbjim carb coughing Nov 28 2020, 09:18 PM
rhodyguy All 4 Venturi read the same at idle? Nov 29 2020, 07:35 AM
dumbjim
yup Nov 29 2020, 10:25 AM
rhodyguy Turn the idle up with the dr side idle speed adj s... Nov 29 2020, 01:03 PM
porschetub
Turn the idle up with the dr side idle speed adj ... Nov 29 2020, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 07:06 PM |
